Old 07-27-2006, 06:49 PM   #16
notjoe
600rwhp here i come
notjoe's Avatar
Send a message via ICQ to notjoe
Originally Posted by AcidSnow
no, just feels like its not getting enough gas.
Whens the last time you've changed your fuel filter?
BTW, dont listen to the manual and DO change your tranny fluid!
notjoe is offline   Reply With Quote
Old 07-27-2006, 06:55 PM   #17
AcidSnow
Boss of Bosses
AcidSnow's Avatar
never changed fuel filter
AcidSnow is offline   Reply With Quote
Old 07-27-2006, 07:05 PM   #18
notjoe
600rwhp here i come
notjoe's Avatar
I would start there.. Your fuel pump might work fine but once it warms up it might have issues pushing the fuel through the filter.
As for changing gears, i do it all the time at like 140.. I'll be crusing then drop it to 3rd (sport mode) to pass then shift back up to D
Old 07-27-2006, 07:48 PM   #19
cisco911
You can shift down at highways speeds...its not a problem, but if you don't feel comfortable, do it at slower speeds like 80kms/h and see if it drops a gear.
Old 07-31-2006, 08:54 AM   #20
AcidSnow
Boss of Bosses
AcidSnow's Avatar
shifting down didn't seem like a problem, I wanted to also note that in the morning if I don't hit the gas pedal before I start, it sometimes won't catch . . .
Old 07-31-2006, 09:03 AM   #21
notjoe
600rwhp here i come
notjoe's Avatar
Get it checked out ASAP. I'm not expect but i do know that you're not supposed to/shouldnt need to step on the gas with a fuel injected car.
I'm guessing maybe a feul pump or dirty injectors
Old 08-29-2006, 06:47 PM   #22
bikemx423
Bayern Motor Werks
Send a message via AIM to bikemx423
Cats might be plugged... Get cold air intake... Try both. A/C turning off for sure??? Listen to it and double check. Thats gotta be it... Also maybe fuel injectors... USe a expensive (like 10$) Fuel clean kit twice in your gas tank... TRY IT!
bikemx423 is offline   Reply With Quote
