Old 08-28-2006, 07:38 AM   #1
wazzzzup
Best brake fluid to use for e36 m3
Hey Guys,
I am going to be flushing my brake system tomorrow and i am looking for some info on what break fluid to use.
What is the best of the best when it comes to brake fluid and where do i find it
wazzzzup is offline   Reply With Quote
Old 08-28-2006, 11:21 AM   #2
wazzzzup
I also need to know how much brake fluid a 99 m3 takes
Old 08-28-2006, 12:25 PM   #3
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
ATE Superblue is a great product, and most BMW's take around a litre. My E30took less than a litre including clutch.
Old 08-28-2006, 02:34 PM   #4
Mitch555
Retired MaXmember!
Mitch555's Avatar
I put this in after I got my steel brake lines put in.
ATE Super Blue has a dry boiling point of 536F and a wet boiling point of 396F.
MY ENGINE SWAP: HERE!
Life Is A Tough Teacher, It Gives You The Test Then The Lesson.
Originally Posted by Mystikal
just do it once, do it right.
Mitch555 is offline   Reply With Quote
Old 08-28-2006, 02:40 PM   #5
wazzzzup
Thanks guys!
I picked up 2 litres of ATE Superblue since i plan on bleeding the clutch and i rather have too much than too little
Old 08-28-2006, 02:50 PM   #6
Gamite
Gamite's Avatar
I had superblue and my brakes were still mushy, I was told that racing fluid is not good for street use becaues the fluid needs to be hot to perform effectively. (Maybe my lines are too old)
Mitch did you notice a big difference?
www.gamite.net
Old 08-28-2006, 02:58 PM   #7
wazzzzup
I was told superblue is pretty much OEM fluid.
I take it you have stock brake lines?
Old 08-28-2006, 03:13 PM   #8
Mitch555
Retired MaXmember!
Mitch555's Avatar
I've had no problem with my brakes at all. I even changed my pads to dustless ceramics too. Feels better when I brake now. I just put the racing fluid in for the times when I REALLY need to use my brakes HARD so it will help me out by not heating up and being all sloppy.
Old 08-28-2006, 03:22 PM   #9
98Dinan3
98Dinan3's Avatar
Superblue here as well. Took less than a liter for clutch and brakes. No problems and seems to perform well.
Old 08-28-2006, 04:18 PM   #10
I use DOT 5.1, not Superblue (only 4).
Didn't notice a difference in feel at all though. Nice to have the high boiling points I suppose.
Old 08-28-2006, 04:31 PM   #11
Gamite
Gamite's Avatar
Dot 5.1 is the highest now, supposedly it has a better "stiffness?" than superblue.
Mitch, you didn't notice much of a difference either right?
www.gamite.net
Old 08-28-2006, 04:42 PM   #12
WASABI
OG
Which ones?
Brake fluid does not get as hot on the street as on the track.
Old 08-28-2006, 05:31 PM   #13
thinair
moderationistismingly
thinair's Avatar
That makes no sense. Who ever told you that must be on crack.
You probably have air trapped in your ABS pump or something.
"Driving is like a narcotic, an addiction that can take over lives. It ruins people, breaks families apart, and even kills. Itís habit that needs to be fueled. Time, money, rationality, sweat, knuckle skin, and anyone who disapproves are of little importance to a driver, and are often overlooked. Hi, Iím Nelson, and Iím a drivaholic."
Old 08-28-2006, 05:35 PM   #14
static
static's Avatar
^ or a master cylinder problem
to original poster: just like almost anything, brake components/fluid is all about compromise. Don't listen to people who say this or that is the best cause it performs the best on track. It might be the best on track, but will screw you over on the street.
I wouldn't buy brake fluid based just on how high the boiling point is. I hear that some fluids have more water absorbancy than others. All those factors and differences add up. Do some research (starting here: http://stoptech.com/tech_info/wp_brakefluid_1a.shtml)
dot 5.1 seems to be the best(?) choice, but if you just drive on the street and far from overheating your fluid, you don't need to spend extra money on super-duper fluids. Super blue fluid seems to work just fine for even avid amature racers.
static is offline   Reply With Quote
Old 08-28-2006, 05:45 PM   #15
NickP
NickP's Avatar
No, just a higher boiling point. If you have mushiness something else is up.
Also note ATE Super Blue also comes in gold; its handy to alternate between the two colours so you know when you're actually getting fresh fluid from the bleeders.
NickP is offline   Reply With Quote
