Old 07-18-2006, 07:14 PM   #1
dgmorr
Valve Adjustment
Hey guys,
I'm going to be doing a valve adjustment on my 2.7 stroker. Can anyone tell me what clearances I should be getting?
325e bottom end
325i head
What other info is needed?
Old 07-18-2006, 09:01 PM   #2
Jordan
the fact that it is a m20 is all that matters here.
tight 0.010
That engine isn't a stroker.
Old 07-19-2006, 04:28 PM   #3
Slowered318
tight 0.010
Diesel crank makes it a stroker right?
Old 07-19-2006, 05:10 PM   #4
Jordan
No, physically changing the stroke length, often along with increasing the bore, makes it a stroker.
The term "stroker" seems to be associated with any m20 with more then 2.5l of displacement. His engine configuration is more acurately called a "2.7i"
Old 07-20-2006, 01:04 AM   #5
dgmorr
Thanks for the valve clearance number.
PS. Sorry that I've ruined your day by using the term stroker that is really losely thrown around...especially since I've had my first BMW for what, maybe less than a month. You gotta start somewhere.
Old 07-20-2006, 03:23 AM   #6
Eurospeed88
Eurospeed88's Avatar
Send a message via AIM to Eurospeed88
That valve clearance spec should also be used when the engine is stone-cold, I would reccomend letting the engine sit overnight, then doing the adjustment.
PNW E30 Crew :: 1986 325es ::
Eurospeed88 is offline   Reply With Quote
Old 07-23-2006, 10:54 PM   #7
dgmorr
Thanks for the input.
I did the valve job today and put everything in spec while the engine was stone cold. 0.010". Closed everything up, started her up, and I have loud ticking. Shut it down and redid everything. All in spec again and double checked. Started it up again and STILL ticking! My engine was not ticking before the valve job - at least not this loud.
I bring it over to my friend's house, he does the job for me, and it's STILL ticking!
Anyone have any ideas how to get it to stop ticking? Should I go lower on the gap? Maybe 0.008 or something? Aything to get rid of the annoying ticks. Are the rockers worn, cam lobes worn? Anything would help.
Thanks.
Old 07-24-2006, 12:55 AM   #8
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
Injectors tick too.
Old 07-24-2006, 05:25 AM   #9
Jordan
M20's will always tick.
If you don't like it sell the car.
Old 07-24-2006, 11:01 AM   #10
Jordan, I don't think you should have sold your e30; your level of dick-ness has gone way up. I presume it's because you miss your car.
A n y w a y . . .
To me, it seems odd that the ticking has increased unless your valves were too tight before the adjustment. When you adjusted them, did you loosen them? If they were too tight, then this is what it was supposed to sound like.
Old 07-24-2006, 11:28 AM   #11
Blades
Your opinion is to long
Blades's Avatar
no .. saturday nights without a girlfriend make it a stroker.
-=[ BL/\DES ]=-
Old 07-24-2006, 04:12 PM   #12
dgmorr
A n y w a y . . .
That's what I'm thinking too.
But yes, I loosened some and tightened others. Some had no gap, while others had to much of a gap. But they are all now in spec. It's a little annoying now, but if it's in spec, I guess that's how it should be?
Old 07-24-2006, 05:21 PM   #13
Jordan
All m20's tick.
it is their freaking nature.
If you don't like it sell the car, or swap in a 24v 6.
Old 07-24-2006, 10:56 PM   #14
BmW1718
Send a message via MSN to BmW1718
yea all e30's tick once u adjust the valves and there right u will hear the injecters they tick pritty good too as jorden says if u don't like ticking than a m20 is not for u
BmW1718 is offline   Reply With Quote
Old 09-14-2007, 10:26 AM   #15
InsaneBimmer
Not_So_Stock
Send a message via AIM to InsaneBimmer
Its taken some getting used to because at first when i was a Bimmer Newb I was constantly checking my oil and couldnt understand but now I do. Now that Ive got an exhaust I only hear it in the garage.
87 E30 325e H&R 2" drop, 17" VIA's, f/r bars, Greddy cat-back
InsaneBimmer is offline   Reply With Quote
