Old 07-15-2006, 02:47 PM   #1
e30_kid89
The Afro-stig
e30_kid89's Avatar
Angry deck fuse keeps on blowing!!!!!!!!!!!!!!!
it started 2 days ago while i was driving my HU started to flicker on and off then just turned off and while it did that it blew fuse 21 on my e30....every time i put a new fuse in it just blew...when i disconnected my deck fuse 21 was working again so i thought that was my problem...and to fix it i tried relocating the power directly to the battery and the ground to a piece of metal.....i plugged in the deck and i heard some werid static noises comming from the speakers then the deck fuse would just blow...this happens every time i put in a new fuse and plug the deck in....can loose speaker wire blow fuses??? what else could be causing the fuse to blow?? gimme something i can work with or that might help me out...
Devon
Old 07-16-2006, 04:28 AM   #2
$500bimmer
check all your connections, just see if there are any bare wires.
Old 07-16-2006, 10:32 AM   #3
e30_kid89
The Afro-stig
e30_kid89's Avatar
i checked ALL wiring and still nothing man.........
Old 07-25-2006, 08:42 AM   #4
Nascar318is
Nascar318is's Avatar
If you have static and your fuse keeps blowing you have a bad ground somewhere. If it's an aftermarket radio check to make sure your wiring is connected properlly. When I installed mine the new wiring harness had different colours of wires on it, so I had to use a 9v batt to find out wich wire was connected to what speaker in the car. The rest is simple, the ground, power are always the same color.
