Old 07-10-2006, 04:49 PM   #1
BennyL
7th Gear Member
BennyL's Avatar
Correct Tire Size For 18's on E36?
Hey guys,
What is the correct tire size for 18's on an E36? Will 225/45/18 fit, or do they need to be lower profile, such as 225/40/18?
Any help is much appreciated. Thanks!
Old 07-10-2006, 05:08 PM   #2
theboss
theboss's Avatar
225/40/18 is recommended....
from what i understand you can go a bit wider in the front and rear but not 45 series.
theboss is offline   Reply With Quote
Old 07-10-2006, 11:09 PM   #3
BennyL
7th Gear Member
BennyL's Avatar
so, at most, 235/40/18 is safe?
Old 07-11-2006, 08:43 PM   #4
It's oversized, probably will rub.
235/35/18 or 245/35/18 is correct.
Old 07-12-2006, 12:41 PM   #5
BennyL
7th Gear Member
BennyL's Avatar
Mystikal: will 225/40/18 rub?
Old 07-12-2006, 06:11 PM   #6
icu
icu's Avatar
Cool re tyre size
Well I have a set of 18" OEM rims on my 98 328 , Fronts 225/Zr 18 88y Rears 255/Zr 18 90y Michelin Pilots , no problems with rubbing before or after the install of T.C Klein's fine suspension that dropped the car a few degrees. Hope this helps in your quest.
icu is offline   Reply With Quote
Old 07-13-2006, 01:45 AM   #7
Justin e36
Justin e36's Avatar
how wide are your rims?
Old 07-13-2006, 09:38 AM   #8
theboss
theboss's Avatar
what is "T.C Klein's fine suspension" ?? ...also you did not state profile specs only width....
Old 07-13-2006, 12:49 PM   #9
guys, you're asking the WRONG questions.
JUSTIN, runs 255's in back, doesn't rub
MITCH runs 19 inch bbs's, and only touches in the rain
PROPR'ONE runs 235/40/18's all around, but since the offset isn't perfect, he rubs
235/40/18 is plenty big for e36, just get the correct offset for your car
Old 07-13-2006, 05:11 PM   #10
icu
icu's Avatar
Thumbs up re profile
Yeah sorry should have read 225/40/zr/18 88y fronts , 255/35/zr18/90y rears, the T.C Kleins suspension is a TCKR True Match S/A coil over system, info on this fine setup is available on his web site TC Klein Racing.com
Old 07-19-2006, 05:33 PM   #11
Mitch555
Retired MaXmember!
Mitch555's Avatar
I don't rub at all... Only if my wheel is turned ALL the way and it BARELY touches the plastic on the inside of the fender. I've even got air in my car (wheels off the ground) and when I came down it didn't rub! (I was actually surprised that I didn't rub!)
MY ENGINE SWAP: HERE!
Life Is A Tough Teacher, It Gives You The Test Then The Lesson.
Originally Posted by Mystikal
just do it once, do it right.
Mitch555 is offline   Reply With Quote
Old 07-19-2006, 11:38 PM   #12
LOL, I think I remember seeing you lift off once during that Halton Hills run we did a few years back.
Old 07-20-2006, 12:33 PM   #13
Mitch555
Retired MaXmember!
Mitch555's Avatar
LOL You might have... my suspension is nice and stiff (but comfortable), it is actually stiffer than H&R Race springs.
Randy saw me get air and Jon was in my car too at the time at a cruise.
Old 07-20-2006, 05:29 PM   #14
LOL, I know it's stiff, the car jitters on every bump.
I know what you mean about the ride though, my GC's are stiffer than H&R Race too and it's still really comfortable.
Old 07-21-2006, 04:51 AM   #15
Mitch555
Retired MaXmember!
Mitch555's Avatar
Oh yea right! I never knew you have GC's too! Good choice meng!
