Old 07-05-2006, 07:34 PM   #1
Bandi
der mechanik
Bandi's Avatar
Send a message via MSN to Bandi
'84 318i won't rev past 1500
Title says it all... feels like it's hitting a rev limiter when I get there. IAC is ok, AFM is okay, tried bumping the ECU around a bit (I've seen the cold solder joints screw up in a few Carerras before).... car seems to want to rev higher if I unhook the beige temp sensor, but it misfires badly when I do this.
It was initally just doing this when I hit a bump, now it won't fix itself.
(edit: upon further investigation... looks like I'm losing injector pulse, if this helps any.)
Any suggestions? Please?!
-'72 2002
-'72 Super Beetle
-'72 Baja Champion SE Beetle
-'66 Beetle
-'74 Sun Bug
-'75 La Grande Bug
-'65 Fiat 1500 Cabriolet
-'99 New Beetle TDi
-'84 Rabbit Cabriolet SportLine
-'91 Tercel GT-S Twin Cam
Bandi is offline   Reply With Quote
Old 07-05-2006, 08:22 PM   #2
Jordan
timing.
Old 07-06-2006, 04:26 PM   #3
Bandi
der mechanik
Bandi's Avatar
Timing is dead on... I was thinking, I guess unhooking the temp sensor would simulate a cold engine, so it's just getting raw fuel from the cold start injector, thus letting it rev.
-'72 2002
-'72 Super Beetle
-'66 Beetle
-'74 Sun Bug
-'75 La Grande Bug
-'99 New Beetle TDi
Old 07-06-2006, 04:50 PM   #4
NOTORIOUS VR
NOTORIOUS VR's Avatar
Have u checked u'r ignition system? like plugs, wires, cap, rotor, coil, etc?
when u pull the plugs, what do they look like? do all 4 look similar? or are there a few that are maybe wet, or some that are black, and other's white or gold?
E36 DYNO TUNING WIRING PARTS
Old 07-06-2006, 06:14 PM   #5
Jordan
Have you had the distributor out lately? Sure you didn't put it back in 180 out?
Old 07-09-2006, 04:10 PM   #6
Bandi
der mechanik
Bandi's Avatar
I haven't but the previous owner did... I actually took it out again and re-indexed it, but it didn't seem to make any difference. (Even tried spinning it 180, but the car ran worse)
I'm actually kind of leaning towards a broken wire... in the pick up or something... simply because if I hit a bump, the car will start acting up. The other day, I drove the thing almost 500 miles without a problem, and then turning on to my road, hit a bump and the car started acting up again.
And maybe I'm nuts, but it seems to me that if I leave the car in the hot sun all day, it'll be fine.
And yes, I've checked plugs & wires, cap & rotor... but when I had a noid light hooked up to the injector harness, it was definitely the injectors cutting out... the light would get really bright and then turn off completely, ignition stays strong when the car is gimping.
-'72 2002
-'72 Super Beetle
-'66 Beetle
-'74 Sun Bug
-'75 La Grande Bug
-'99 New Beetle TDi
Old 07-11-2006, 01:00 AM   #7
Bandi
der mechanik
Bandi's Avatar
BTW Jordan... love the new ride.
Now... think you can convince Misty to pose on my '72 2002?
-'72 2002
-'72 Super Beetle
-'66 Beetle
-'74 Sun Bug
-'75 La Grande Bug
-'99 New Beetle TDi
