Old 07-04-2006, 07:56 PM   #1
Magic_Black
BMW ID Designer
Magic_Black's Avatar
M30 AFM & E36 steering rack headaches...............
I decided to install an e36 steering rack and M30 AFM into my e30 this past week. (Note: to anyone doing these swaps, they aren't as easy as everyone may say it is.) after going through an entire week of stressing to complete these two projects on my E30, i finally completed both projects and had high hopes that they both would of turned out well.....
Unfortunatley i was wrong.
I think i messed up the E36 steering rack high pressure PS line, i bent it every which way to fit it and after being so fatigued by it, i think i bent it a little too much and know there are two kinks in the pipe at both ends of the high pressure PS line. So if anyone has a spare E36 High pressure PS line they are willing to sell, please let me know ASAP!!!
With the M30 AFM, i did the swap correctly and reused my stock airbox, but not until a few minutes ago did i realize i was supposed to also swap the M#) electronics with the M20 electronics. That may be the problem and the reason why my e30 is not idiling properly and the check engine lights comes on after 25 seconds or so after i take my foot off the accelerator.
Anywayz if anyone can help me out with my situation and/or give some advice please let me know.............
Magic_Black is offline   Reply With Quote
Old 07-04-2006, 08:50 PM   #2
Jordan
Just because you have no freaking clue what you are doing doesn't mean its hard. Maybe "everyone" that says its easy just knows how to do it right?
I've done both of those swaps many times without any issues, and quickly at that...
Old 07-05-2006, 01:21 PM   #3
NOTORIOUS VR
NOTORIOUS VR's Avatar
^^^^ Shut up
Magic_Black try this link: http://www.davelength.net/car/bigsix.html
EDIT: btw, the M30 AFM with the part # that ends in 027 should be a direct plug an play unit.... others u'll have to do a board swap.
EDIT #2: I also have a plug and play M30 AFM FS here: http://www.maxbimmer.com/forums/show...408#post835408
Old 07-05-2006, 07:00 PM   #4
Euro_E30
Euro_E30's Avatar
did you swap the M20 internals into the M30 AFM??
Euro_E30 is offline   Reply With Quote
Old 07-06-2006, 01:31 AM   #5
1. You don't need to swap electronics.
2. You need to adjust the tension spring.
Old 07-06-2006, 11:05 AM   #6
Magic_Black
BMW ID Designer
I have the M30 AFM that ends in part number 027. I didn't know all i had to do was just adjust the tension spring though.
I changed the M30 circuit board to the M20 one today, still wasn't idiling properly, so i did play around with tension spring until i got it to idle right. However, i had to set the metal which contacts with the circuit board a little high for the car to idle properly. Now if the car is turned off, from where that metal is set I can move it by hand and it will actually run off the circuit board at the other end of the circuit. Should i be worried about the contact running off the circuit board. If it does create a hassle, it will only take 5 mins to put back the M30 circuit board back in.
Old 07-06-2006, 08:54 PM   #7
Euro_E30
Euro_E30's Avatar
i did the complete swap from m20 to m30 without turning the spring at all, and my car runs mint.
Old 07-06-2006, 09:14 PM   #8
Jordan
NEVER adjust the tention spring. If you do you have ruined the laser trimmed calibration of the AFM unit.
And you screwed with the swing arm.. man you completely trashed the calibration of that AFM. Its junk now.
Old 07-07-2006, 01:39 AM   #9
Magic_Black
BMW ID Designer
When i installed the M30 AFM with part number ending in 027 and started my car the car was NOT idling right. so explain what the problem would be?
Old 07-07-2006, 05:33 AM   #10
Jordan
Um.. the ECU doesn't magically adapt. Or that AFM is bad.
Old 07-07-2006, 01:06 PM   #11
NOTORIOUS VR
that is true... the ecu needs to compensate for the new AFM.. and it only does this over time... it won't happen right away.
Old 07-07-2006, 07:13 PM   #12
I still refuse to believe that, although empirical evidence would change my stance quickly.
I have tried multiple 027 AFM's on my car (whose factory AFM has never been tampered with), and none of them would run right. After adjustment, they all do. And I'll be damned if my car is running with a "junk" AFM now, it's been great for months.
Old 07-07-2006, 07:14 PM   #13
Motronic 1.3 doesn't adapt to anything, in modern terms of the word adapt. If something doesn't run right in the first 30 seconds of driving on an M20, it never will.
Old 07-08-2006, 12:51 AM   #14
Jordan
Mine idled like shit intially when I installed my 027 (pre HFM conversion) after some driving around it picked it up fine.
Do not mess with the spring tention and under not circumstances bend the swing arm left or right.
Old 07-08-2006, 09:21 AM   #15
All of the ones I tried would refuse to idle at first, so I drove around for quite a while manually idling with the throttle, and it still never fixed itself.
And I know one of them was never tampered with, I had one of your old "pals" at TSA get it for me with the factory sealing still present.
