Old 07-03-2006, 10:53 AM   #1
Xander25
Post Need Some Help!!!
Ok i have a white 90' 525i thats kinda on the slow side i wanna tune it out to the fullest i just dont know were to start can anyone give me a list or tell me what i need to do to get this car going....
Xander25 is offline   Reply With Quote
Old 07-03-2006, 01:33 PM   #2
NOTORIOUS VR
NOTORIOUS VR's Avatar
there's not too much u can do... big car, small motor...
if you do decide to go with forced induction it'll be faster, but you should have really started with a bigger motor especially with that size car...
so what you need to do is find a capable shop that will either A) swap in a V8 or 3.5L six and/or B) turbo or supercharge the V8 or turbo the 3.5L six.
be ready to spend big money to make that car fast.
I wouldn't even wast u'r money on a chip, exhaust, etc for u'r current motor.
That motor is slow in a 3 series, never mind a 5er.
Old 07-07-2006, 02:59 AM   #3
Boost should be the last thing on your mind. You can build up an m50 to 500+ HP, but its just cheaper to swap a 4.0 in and mod/boost that, same results with better reliability and less money spent
Old 07-07-2006, 10:54 AM   #4
SickFinga
SickFinga's Avatar
lol
Old 07-07-2006, 03:48 PM   #5
Furious
BMW again.
Furious's Avatar
+1 @ lol
Old 07-08-2006, 03:46 AM   #6
ulysses has a m52 putting down 600+ on stock internals. You saying it can't be done?
Old 07-08-2006, 04:02 PM   #7
NOTORIOUS VR
What does that have to do with anything? The problem is, stock internals will fail after a certain point... Of course it can be done, but going with a forged bottom end will give you the reliability aspect.
and for the record 600+ on stock internals, is definatly NOT on pump gas.
But I'd like to see a list of his setup if you can point me to a site/forum... I did a search for his username on Max but he doesn't exist.
Old 07-08-2006, 04:44 PM   #8
"My car is a 1997 328i.The motor is a 2.8 liter at this time the motor has pushed 635 horse power to the wheels.Getting that power to the ground is another story. The best part is, it is a all stock motor except a m50 manifold and low compression gasket.
635Whp 590Wtq Built and installed By ICS
Engine:Stock 2.8 liter,M50 manifold,550 injectors,Cometic head gasket,Arp head studs
turbo:Gt35/40, ICS custom piping with 4 inch intake,E-boost controller,hks 40mm waste gate,AA exhaust manifold,Spearco intercooler, AA Alcohol/water injection,greddy boost and fuel gauge,aem afr meter,ics custom 3 inch exhaust,greddy turbo timer
Stock Ecu, AA/Ics tuned
Nx express Intercooler spray,DEI co2 fuel and air cooler
Fuel:walbro255 pump,ICS fuel rail,Aeromotive fuel pressure reg.
Trans:M3 5 speed,Clutch masters fx800 dual disc ceramic bronzed clutch,cluth masters light weight flywheel,UUC evo 3 shifter,UUC steel braided clutch line,UUC trany reinforcment bushings and cups,UUC Clutch stop
M3 rear frame,Turner solid frame bushings,turner weld in reinforcment plates,turner solid mono ball trailing arm bushings,UUC Adjustable Rear Control Arms,H&R lowering springs
M3 differential with 3.15 gears
VIS carbon fiber trunk and hood
Kosei 16x7 front
kosei 17x8.5 rear, Nitto drag radials 245/45/17"
www.bmw328turbo.com
and i'll point out
i never said anything about running on pump gas
Old 07-08-2006, 06:23 PM   #9
NOTORIOUS VR
the site doesn't work.. or the link is incorrect
Old 07-08-2006, 06:29 PM   #10
ZiMMie
Start with a basic tune up first. Before thinkin about mods.
Timing Belt,water pump, Spark Plugs,fuel/air Filter,distributer car/rotor.
Shit lke that.
#E36-S54 #CSLWannabe
Old 07-08-2006, 07:08 PM   #11
Justin e36
Justin e36's Avatar
I'm confused.
I think they were lol'ing at your first statement about building up a m50 to 500+hp without boost.
Then you said "You saying it can't be done?" and proceeded to prove them wrong with an example...
But the example you used has a boosted engine, and the engine is NOT built up. It's still on stock internals.
I thought you were proving that it can be done naturally aspirated by building the engine up?
Old 07-09-2006, 02:53 PM   #12
Originally Posted by Justin e36
I'm confused.
You're right, i phrased that incorrectly. But since this is in a post in a section called Forced Induction, it can be assumed that the modifications to said engine will involve FI. The biggest gap in what i said is that cardcounters engine is a m52, not an m50, but if i have some time i'll look up a FI m50 that makes those numbers aswell. (AA has tons of m50's on thier site hitting those numbers)
http://www.bmwturbo328.com/ is the correct link, and he puts out 635 WHP on stock internals.
Old 07-13-2006, 04:19 PM   #13
Furious
BMW again.
Furious's Avatar
cardcounters car is impressive, but lets look at it like this its 635 on race gas and stock internals plus countless headgaskets, and studs. if you can afford to have to pull the engine apart and change the HG than thats all and well but almost all of us cant afford that either it being downtime or cost.
the way you did phrase it was like you ment build up as in NA, on boost you can make any engine run big numbers but for how long and how reliable? its not a good example, impressive example, but not a good one.
Old 07-14-2006, 11:42 AM   #14
thinair
moderationistismingly
thinair's Avatar
As a note, the 328 engine (M52B28) has a forged crank, stock. The hardest part so I've heard is keeping the head sealed to the block (blowing gaskets, head distortion, etc)
Old 07-16-2006, 03:18 AM   #15
Mark, i'll point out yet again, that i was talking about what COULD be done, not what SHOULD be done, and that i posted that there are more effective alternatives that are both cheaper and more reliable.
