Old 11-13-2002, 12:16 AM   #1
Autotechnica
Little Chino
WTB: used or new E36 control arms or busings
I need to replace my driver side control arm bushings. If you have a used control arm and want to sell let me know, thanks
Bryan
Old 11-13-2002, 02:05 AM   #2
KIRASIR
Your Nightmare
KIRASIR's Avatar
Huh?
Bryan, the bushings are about 40bucks brand new from the dealer. Why on earth do you need used control arm/bushings?
BTW once you take the bushings out of the brackets you won't be able to reuse them, also they should be replaced in pairs.
Serge
Old 11-13-2002, 09:39 AM   #3
Autotechnica
Little Chino
Originally posted by KIRASIR
Huh?
Serge
Serge,
Charlie has informed me it might actually be cheaper to get a used control arm (complete w/ all the bushings) and just swap it that way. The labour would costs more if I simply changed the bushings.
Unless you can do it for me
Bryan
Old 11-13-2002, 09:57 AM   #4
KIRASIR
Your Nightmare
KIRASIR's Avatar
This doesn't make sense since the bushings can be changed without taking the arms off. You just need a special tool to put the new bushings onto the arms. I believe Charlie has it for sure.
With the tool, and on a hoist, it takes about an hour to change the bushings.
Serge
Originally posted by Autotechnica
Serge,
Bryan
Old 11-13-2002, 01:15 PM   #5
Autotechnica
Little Chino
Serge
Serge,
Actually the middle bushing and inner bushing of the control arm on the inside has to be change on the driver side. So I think removal of the control arm is necessary correct? Are all 3 bushings on the control arm $40 each? I'm getting a strange noise when I corner hard turning right only, and quite a bit of understeer, do you think it could be cased by the worn busings on the control arm?
Thanks!
Bryan
Old 11-13-2002, 01:24 PM   #6
hawai-Ian
hawai-Ian's Avatar
Last time I had my bushing replaced, my ex-mech (haha) had a BIATCH of a time removin just the bushing so he had to remove the control arm to get to that bushy thingy.
Cost me 2 hrs labour.
hawai-Ian is offline   Reply With Quote
Old 11-13-2002, 02:06 PM   #7
KIRASIR
Your Nightmare
KIRASIR's Avatar
Okie...Stop right there!
Terminology lesson:
Controls arms have 3 points of attachment to the car.
1) Outer ball joint
2) Inner ball joint
3) Control Arm bushing
So 2 arms have: 4 ball joints and 2 bushings.
Inner ball joints are not replacable and have to be replaced with the arms.
What kind of sound are you experiencing? Clicking noise when turning right or left?
Serge
Serge,
Thanks!
Bryan
Old 11-13-2002, 02:07 PM   #8
KIRASIR
Your Nightmare
KIRASIR's Avatar
Removing the bushings is actually pretty easy. All you need is a 3 leg puller. Putting them back on is another story. You need a special too for that.
SL
Old 11-13-2002, 04:41 PM   #9
Autotechnica
Little Chino
Terminology lesson:
1) Outer ball joint
2) Inner ball joint
Serge
I noticed a plastic seal or rubber bushing around the inner ball joint. All the ball joints have been recently replaced so I'm positive it's not that. Any idea what I'm talking about? I'll try to find pictures if I can. The rubber seal around the ball joint appears to be worn. Charlie said it had to be replaced. Any ideas? Thanks!
Bryan
Old 11-14-2002, 01:13 AM   #10
KIRASIR
Your Nightmare
KIRASIR's Avatar
Okie,
Looks like you are talking about a balljoint rubber boot( I think that's how it's called)
Which one is worn, the outer or the inner? How worn is it?
Serge
Bryan
Old 11-14-2002, 12:31 PM   #11
Autotechnica
Little Chino
Okie,
Serge
It's the inner rubber boot then, the one closer to the rear end of the car. Anyways, how bad is it? Compared to the passenger side one which looks next to perfect condition, the driver side one looks like someone took a rusty knife and stabbed the sh*t out of it.. hahah. Another words, pretty bad.
Bryan
Old 11-14-2002, 02:18 PM   #12
KIRASIR
Your Nightmare
KIRASIR's Avatar
Hmm...Sounds like you are up for replacing both of the arms.
Unless you can find just the boot somewhere, then you could probably change just the rubber priece. Getting a used control arm would be a pain as well, since you are going to end up replacing the bushing.
Serge
Bryan
Old 11-14-2002, 08:55 PM   #13
Autotechnica
Little Chino
Serge
I don't suppose they sell just the boots?
I've seen TMS sell something called "ball joint dust boot" and it comes in urethane, is this what I'm looking for?
Thanks,
Bryan
Old 11-14-2002, 10:42 PM   #14
KIRASIR
Your Nightmare
KIRASIR's Avatar
Sounds like it.
Thanks,
Bryan
