Old 06-17-2006, 01:52 PM   #1
Rush
Rush's Avatar
Crank Sensor e39
Anybody know where is it located and how do I replace it?
Rush is offline   Reply With Quote
Old 06-17-2006, 02:02 PM   #2
O.S.
O.S.'s Avatar
go to http://www.bmwtips.com/
click Tips and Tricks
then find Cam Position Sensor Replacement writeup
cheers
F10 535xi M-Sport, Dark Graphite
E39 540i Sport Titanium Silver - SOLD
E34 520 Black - SOLD
O.S. is offline   Reply With Quote
Old 06-17-2006, 03:05 PM   #3
Quack
Wheelman
Quack's Avatar
Cam sensor isn't the same as a crank sensor, most likely the crank sensor is located on top of your tranny housing very close to the engine block, it normally reads off the ring gear
Quack is online now   Reply With Quote
Old 06-17-2006, 04:09 PM   #4
O.S.
O.S.'s Avatar
at least I tried
Old 06-17-2006, 08:21 PM   #5
Rush
Rush's Avatar
Found it and replaced ... pretty easy. Thank you
Old 06-17-2006, 09:05 PM   #6
Quack
Wheelman
Quack's Avatar
where was the crank sensor located? it would be nice to know for future reference for other members
Old 06-18-2006, 02:56 AM   #7
Rush
Rush's Avatar
pic attached ...
Old 06-18-2006, 03:04 AM   #8
Quack
Wheelman
Quack's Avatar
that's the cam position sensor, I thought you were looking for the crank sensor
Old 06-18-2006, 12:28 PM   #9
Rush
Rush's Avatar
Turns out it's the same thing ... got me confused too.
Old 06-18-2006, 01:52 PM   #10
Quack
Wheelman
Quack's Avatar
well I know some cars have both & some cars don't have the crank sensor because it pretty much gets the same results, the cars ECU can figure it out, I guess our E39's only needs one
Old 06-18-2006, 11:23 PM   #11
RMPMOTORS
RMPMOTORS's Avatar
E39 have both a cam and crank sensors, the crank sensor on the 4.4 is on the bottom of the bellhousing on the transmission right side, on the 6cyl models its in the block lower left side.
Rocco
www.RMPMOTORS.com
www.Facebook.com/RMPMotors
Old 06-18-2006, 11:39 PM   #12
Quack
Wheelman
Quack's Avatar
thanks for clearing that up Rocco
Clarence
Old 06-29-2006, 08:11 PM   #13
NOTORIOUS VR
NOTORIOUS VR's Avatar
most EFI cars have both a CAM and CRANK sensor... and they are not the same thing.... the crank sensor gives the ECU the engine speed signal (which is also used to firing the ignition), and the CAM sensor is for thing like sequential injection control, cyl. dependant knock sensing, etc, etc...
E36 · VEMS · TUNING
Google Talk: NOTORIOUS VR
