Old 06-07-2006, 07:04 AM   #1
Furious
BMW again.
Furious's Avatar
wideband O2 gauges..
guys is this compatable with my car?
i know its universal but still need to double check
http://cgi.ebay.ca/AEM-UEGO-30-4100-...QQcmdZViewItem
Old 06-07-2006, 07:37 AM   #2
bubsy12
bubsy12's Avatar
Send a message via ICQ to bubsy12 Send a message via AIM to bubsy12
Yep, those aem gauges/probes are great and can be used with any n/a or f/i setup.
Sean
2008 Toyota Rav4 V6 AWD Sport - Daily Driver -
www.SpoolnU.com - ALPHA. SIGMA. BOOST.
bubsy12 is offline   Reply With Quote
Old 06-07-2006, 07:42 AM   #3
SickFinga
SickFinga's Avatar
Mark, it is compatable with ANY car.
You going to have to get a bung installed in your exhaust, and you are good to go.
The only difference is that there are couple of different versions.
One shows AFR (11.0-16.0), another shows LAMBDA ratio, and another show AFR Volts.
The one you need is AFR.
The one on ebay has both, AFR and LAMBDA, so it should work.
Old 06-07-2006, 12:57 PM   #4
Furious
BMW again.
Furious's Avatar
do i care about lambda control?
Old 06-07-2006, 01:16 PM   #5
SickFinga
SickFinga's Avatar
Nope
Old 06-07-2006, 04:35 PM   #6
Furious
BMW again.
Furious's Avatar
i didnt think so, sounds good, looks like i have my 5th and final gauge.
Old 06-07-2006, 08:10 PM   #7
bubsy12
bubsy12's Avatar
LOL, Welcome to the "Pilots Club" LOL
Sean
Old 06-07-2006, 11:41 PM   #8
KIRASIR
Your Nightmare
KIRASIR's Avatar
You would be better off with this:
http://www.innovatemotorsports.com/x...me.php?cat=253
configured with a regular a/f gauge. It would be about the same price as the gauge you posted, but with A LOT more flexibility (dataloging, aux outputs, etc).
SL
Old 06-08-2006, 12:13 AM   #9
Furious
BMW again.
Furious's Avatar
ive been looking at this type of stuff, because i do have a narrow band gauge.
Old 06-08-2006, 01:10 AM   #10
skillton
Send a message via ICQ to skillton
SL
It would be about $150 more. That link you posted doesn't include the gauge itself
I would go with something that has datalogging capibilities, the AEM doesnt
skillton is offline   Reply With Quote
Old 06-08-2006, 02:17 AM   #11
Furious
BMW again.
Furious's Avatar
i realize that, but i really dont need to data log too much, i mean im running on a canned software, its not stand alone. the tune is set, i only want the gauge to make sure that during dramatic temp changes like we see in canada, that the car wont lean out too much.
Old 06-09-2006, 07:07 AM   #12
MarkD
MarkD's Avatar
Mark,
do you really think you are going to be driving and looking at the gauge also?
Get an Innovate system (they are the best available ) and if you buy the right one, you can log data. Then, if the data indicates that the car needs some fine tuning, it can be done. The Innovate system stores 12 samples every second, so is very useful for tuning. It's the system I use.
MarkD
Old 06-09-2006, 12:46 PM   #13
Furious
BMW again.
Furious's Avatar
i already got the AEM on the way, i looked at the innovate system, and i really dont need it, im not going to be looking at the gauge much, but i will be keeping an eye on it. if i were stand alone i would have opted for the innovate system. but my chip isnt easy to tune or will it be often i tune it, probably once more ill get a reburn i have to check two things first, 1. proper fuel pressure, 2. my MAF is clean.
than another dyno run and if need be ill be sending my data back to AA for a reburn.
Old 06-09-2006, 12:55 PM   #14
MarkD
MarkD's Avatar
Then you won't be getting any useful info from it. It will just be there for "show".
Who says it's not easy to tune?
The data you got from that dyno run is useless for tuning for 2 reasons:
1) a/f ratio measured after the cat
2) exhaust being sampled out of sync with the rpm sampling.
I pointed out to Vlad that the a/f ratio is lagging the rpm display by about 4 to 5 hundred rpm. Vlad agreed after I explained it to him and discussed the results of his run.
Old 06-09-2006, 02:46 PM   #15
Furious
BMW again.
Furious's Avatar
show? i said im going to use it, all i mean is that im not going to be constantly watching it, im able to see where i am while im driving at a glance. again this is pointless to argue about as i already purchased it on ebay and its on route. so too late.
i said its not.
regardless the dynos gave me a decent idea of whats going on, its not useless and i dont understand how you would think it would be, i mean your able to determine data from it, so its not "useless"
