Old 06-06-2006, 05:35 PM   #1
Domvr6
wiring new head unit
has anyone wired in there own head unit? there is that big harness with all the wires then theres that little one with just a bigger black wire leading to it.
i wired everything up but that little black thing and i get no sound. so i look in the back and figure out its to the amp now how do i get the amp to come on with my new cd player.
thanks
Domvr6 is offline   Reply With Quote
Old 06-06-2006, 08:03 PM   #2
spooner_dee
Has no idea whats goin on
spooner_dee's Avatar
i think your supposed to connect the amp to the antenna wire, so that way when you turn the ignition on it turns your amp on, we all have faced this when we put in an aftermarket radio.
Old 06-06-2006, 08:10 PM   #3
$500bimmer
i bought the aftermarket harness! and no DO NOT hook up the ant remote wire to turn your amp on, if you do you wont get any sound when your listening to cds. you have to hook it u to the acc wire but the best is tohook i up to the amp remote wire.
the thing with the ant wire is the it only pulses power for a few seconds then no power till you turn it off trust me lol i learned first hand
Old 06-06-2006, 08:16 PM   #4
Domvr6
well its a connector not just a wire hanging. am i supposed to cut through that thick wire to get the the other wires under it.
Old 06-06-2006, 10:00 PM   #5
$500bimmer
ill check my wiring harness when i go to my shop tom. off hand i cant remember
Old 06-07-2006, 09:33 AM   #6
Domvr6
i figured it out i wasnt connecting my remote wire long enough when i was checking to turn the amp on. so its all good now.
thanks
Old 06-10-2006, 11:04 PM   #7
Shark
Shark's Avatar
which colour or where, is the stock amp wire?
Shark is offline   Reply With Quote
Old 07-14-2006, 01:15 AM   #8
///Milan
///Milan's Avatar
So what was the end result? What did you end up hooking the amp wire up to?
///Milan is offline   Reply With Quote
Old 07-14-2006, 11:47 AM   #9
Shark
Shark's Avatar
Connect the blue/white wire to get the amp to work
Old 07-14-2006, 12:11 PM   #10
///Milan
///Milan's Avatar
SO I have to cut off the end of the amp wire with the plug and then connect it to the blue/white wire?
Old 07-14-2006, 12:33 PM   #11
Shark
Shark's Avatar
are you running a stock deck or aftermarket deck?
For an aftermarket deck, the blue/white wire can run either a stock amp or an aftermarket amp. But for the stock amp, if you get have a wiring harness (look at the pic), you have to connect the blue/white to the solid blue wire. For an aftermarket amp, just connect the blue/white to the remote input on the amp.
Old 07-14-2006, 06:29 PM   #12
///Milan
///Milan's Avatar
Ok, I finally got it, haha. Thanks everyone for the help. But now I need speakers.. .
