Old 06-01-2006, 11:26 AM   #1
Nascar318is
Nascar318is's Avatar
Amp Cuts Out
I'll be driving along and then the amp will cut out then come back then out...turn the volume down and the amp is fine, then it starts cutting out again. Eventually I need a hearing aid to listen to the radio. The amp came with a 35amp fuse, and I can't find them anywhere, so I have a 30 for now. I need to go to a stereo shop and get a 35.
Could that be the problem? Or is it cause the amp gets so hot that you can boil an egg on it. It's a
1000W amp powering 2 x 400w subs in Mono.
Old 06-01-2006, 04:01 PM   #2
JMW
Pole busted to boosted.
JMW's Avatar
it is because you amp is overheating, so it cuts out to protect the amp...my pheonix gold titanium series does it sometimes to on hot days, when im pounding the system with the seats up......take it to ure local audio shop and get it tested for voltage..
it make be over working and surging as well...yo need to get this checked before you damage the amp...
but yes, over heating is the problem..hope this helps
-neil
JMW is offline   Reply With Quote
Old 06-01-2006, 04:53 PM   #3
BMWFORLIFE
Technoviolet Shifting
Neil Shut up! you know nothing
BEEEEEEEE EMMMMMMMM DOUBLEUUUU
BMWFORLIFE is offline   Reply With Quote
Old 06-02-2006, 12:03 AM   #4
JMW
JMW's Avatar
man im serious..thats why.
Old 06-02-2006, 01:37 AM   #5
$500bimmer
yup hes right.could be that. are the subs svc dvc? how do you have them wired??
Old 06-02-2006, 02:58 AM   #6
Jase
twisted beyond reason
Jase's Avatar
I have heard of this as... power clipping. Ususally cause by a bad ground or too small of wires( power). Even as bad as not enough juice from the alternator. I would check to see how it is hooked up before i get the amp checked.
IMO
Jase
Old 06-02-2006, 03:19 AM   #7
paul christians
87325is///MR.EVIL
^^^F.T.W.........I was just going to say that!!!!
87is325///2.7L..EVIL.....
Old 06-02-2006, 07:45 AM   #8
chrille
Boostaddict
chrille's Avatar
Send a message via MSN to chrille
Even if the amp is 2xch it´s not very common that you can runt it in 1x2ohm so my suggestions is to but one woofer on each channel.
chrille is offline   Reply With Quote
Old 06-02-2006, 09:44 AM   #9
Nascar318is
I have 8 guage wire 2 subs on mono the 2 subs are hooked to each other then one runs into the amp....
As for hooking up the subs individually, forget it...not enough bass.
Old 06-02-2006, 11:00 AM   #10
JMW
JMW's Avatar
i think ure over powering ure subs..and that why ure amp heatin up...what kind of amp is it..
and what kinda subs?
Old 06-02-2006, 11:08 AM   #11
Nascar318is
Pioneers for the subs and the amp was a $50 Peice of Crap amp...Dunno the name, but the american flag is on the box, I'd have to check when I get home... So over powering my amp? Should I get a bigger amp? Maybe 1500W?
Old 06-02-2006, 11:12 AM   #12
JMW
JMW's Avatar
nooo im thinkin amp too powerful for speakers...
u see...audios weird..
u really need to make sure everyting tuned properly...cause over powered amp could affect the amp negatively..or the speakers....and vise versa...i dont kno enough about it though..but no..u dont need more poweful amp lol u need a less powerful one..or u should turn the gain down on the amp...cause its prob runnign too powerful for the subs...ure amps def over working..since its over heating...ither get ti fixed by shop, by gettin them to check voltage..to see if u runnin at proper voltage..orr get a better amp, that has better coolling system..
also this will prevent u from blowing the subs as well...
Old 06-02-2006, 11:39 AM   #13
Nascar318is
Yeah that's what I was thinking, should get a liquid cooled amp with 800W. I'll check my gain and that later. And one point I was going through fuse like they were going out of style...
Old 06-02-2006, 01:10 PM   #14
paul christians
87325is///MR.EVIL
no lliquid cooled amps,they are not that good as they say it is,byt fan cooled are the best in my mind to go with........and to the power thing again..if you have a sud that is 250rms you can use an amp that is 300 or 350rms and not peck,peck is only at turn on of an amp that is 5 to 10 secounds of that,put the gain of this amp at 8 or 9 o'clock..
Old 06-02-2006, 06:19 PM   #15
paul christians
87325is///MR.EVIL
OK, I was just thinking about this and came up with this too,check all connections and the fues.............
