Old 05-22-2006, 09:54 PM   #1
mirek
mirek's Avatar
320 front sway bar size
what size does the 320i have? same as 325?
Old 05-23-2006, 06:08 PM   #2
superman123
slushbox champion
ill check ...i have both
but they mount diff
325 mounts to the struts and the 320 doesnt
and i have an exstra 325 swaybar if u wanne do the convertion
superman123 is offline   Reply With Quote
Old 05-23-2006, 06:19 PM   #3
Soldo
Soldo's Avatar
325 mounts to the strut only in 92..... so the 320 should be the same as the 325, but i'm not sure on the size! Didn't the SPORT PKG 325 come with a fatter sway anyways?
Keven Soldo
Old 05-23-2006, 06:38 PM   #4
mirek
mirek's Avatar
can you please measure, i'd really appreciate it.
early 92 mount like the m3 to the strut, and later just to the C-arms.
The 318IS came with the fattest sways, dont know about 325's...
Old 05-24-2006, 04:32 PM   #5
niks325i
niks325i's Avatar
E36 Sway Bar Sizes
BMW - OEM 1995 M3 22.5mm Front / 19mm Rear
BMW - OEM 1996+ M3
23mm Front / 20mm Rear
BMW - OEM 325/328 Base 24mm Front / 15mm Rear
BMW - OEM 325/328 Sport Package 25.5mm Front / 18mm Rear
Eibach M3 style 26mm Front / 24mm Rear adjustable
Eibach 325/328/318 28mm Front / 21mm Rear adjustable
UUC Motorwerks 25.4mm Front / 23.8mm Rear adjustable
Turner Motorsports 27mm Front / 24mm Rear adjustable
RD 27mm Front / 22.2mm Rear adjustable
Dinan 22.2mm Front / 22.2mm Rear adjustable
H&R
28mm Front / 21mm adjustable
Nik
niks325i is offline   Reply With Quote
Old 05-24-2006, 04:44 PM   #6
Justin e36
Justin e36's Avatar
To add to the list...
Korman - 27mm Front / 22mm Rear adjustable
AC Schnitzer - 30mm Front / 26mm Rear adjustable
Interestingly, I have both M3 sways and Dinan... the Dinan's are visibly much MUCH bigger. That shouldn't be the case according to this list. Hmm.
Old 05-24-2006, 05:17 PM   #7
mirek
mirek's Avatar
What's the size of the 320
Old 05-24-2006, 05:21 PM   #8
Justin e36
Justin e36's Avatar
no clue.......
but if you have time to burn, you can compare part numbers on realoem and see if it's the same as the 325 or 318, then use the above chart to figure it out..
Old 05-24-2006, 05:44 PM   #9
01 STABILIZER BAR FRONT D=24MM 1 06/1992 31351090858 $156.24
E36: Details on E36
E36 320i SEDAN
E36 323i CONVERTIBLE
E36 323i COUPE
E36 325i CONVERTIBLE
E36 325i SEDAN
E36 325is COUPE
E36 328i CONVERTIBLE
E36 328i SEDAN
E36 328i COUPE
Old 05-24-2006, 06:23 PM   #10
mirek
mirek's Avatar
thnx
Old 05-24-2006, 06:30 PM   #11
np
Old 05-24-2006, 07:10 PM   #12
Justin e36
Justin e36's Avatar
Originally Posted by mirek
thnx
Originally Posted by propr'one
np
aww... maxbimmer kodak moment here.
Old 05-24-2006, 07:26 PM   #13
mirek
mirek's Avatar
Actually it's more like this
Old 05-24-2006, 11:55 PM   #14
you guys are all bitches.
