Old 05-21-2006, 05:36 PM   #1
keke_167
lowered suspension and rims+tires
i have H&R sport spirngs installed and i have 18 inch rims. the rims are all 18*8.5 and i would like to do a staggered tire setup. would 255/35/18 fit in the rears without any modifications? and also i f i have these in the back what size should i put in the front?
keke_167 is offline   Reply With Quote
Old 05-21-2006, 05:47 PM   #2
Justin e36
Justin e36's Avatar
I have the same drop, same size rims, and I have 255's on the back.
You'll need to modify.
Old 05-21-2006, 06:24 PM   #3
keke_167
what kind of modification and where did you do it. also how much am i going to spend on this modifiction?
Old 05-21-2006, 06:31 PM   #4
Justin e36
Justin e36's Avatar
I had to stiffen my springs and roll my fenders... did it by hand though. If you go to a shop like WHeel & Tire Zone to roll your fenders you'd be looking at around $150 for both sides... still doesn't guarantee they won't rub during hard cornering. Of course the offset of your rims play a major factor too.
this is how it looks when dropped.. there's a lot more wheel tuck than how it looks in the pictures... though the 18's don't tuck as much as my 16 winter wheels for some reason.
http://www.maxbimmer.com/forums/show...9&postcount=19
http://www.maxbimmer.com/forums/show...9&postcount=47
Old 05-21-2006, 06:39 PM   #5
except for i sincerely doubt your car will look as good as justins
just want to point out that offset makes a HUGE difference. Im on stock suspension, with 235's in back, and i rub
Old 05-21-2006, 09:18 PM   #6
keke_167
35mm offset and a 1993 325i
Old 05-21-2006, 10:07 PM   #7
Justin e36
Justin e36's Avatar
same as mine then. as I said above, you'll need to modify.
