Old 05-21-2006, 04:53 PM   #1
325iSBimmer
///MMMM VIDA
325iSBimmer's Avatar
Question Interior Carpet & Gas Pedal Removal
Im in the process of removing my carpets and Im stuck trying to get the gas pedal out. I've tried looking in behind with a mirror and prying up with 2 pry bars and still nothing. Has anyone mastered a technique of getting the go fast pedal out WITHOUT breaking it
ALSO, has anyone here fully removed their carpets and if so how much of the dashboard did you dismantle. I have the center console out but Im looking at it and looks like I need to remove a lot of the HVAC stuff?!
PITA but its a must do because the car is going to be sandblasted and there are some nasty surprises awaiting me underneath that carpet.
Pics to follow soon.
UNDER CONSTRUCTION
Old 05-21-2006, 05:46 PM   #2
Justin e36
Justin e36's Avatar
The problem with the gas pedal removal is the retaining clips will be broken, so you'll have to replace it with a new pedal. I've done it a few times without breaking anything.. but chances are, you'll break the clips.
Remove the retaining clip at the top of the pedal. You'll see it's connected to the throttle cable.
And obviously the pedal must be anchored to the floor somehow, right? (most people don't think about this for some reason). Push the carpet down at the front of the pedal, and there's a little hidden trap door down there. Pry the bottom part of the pedal open, and you'[ll see the retaining clip down there. This is difficult to explain, but you need to press the retaining clips while lifting the pedal.
Make sure when you install your new pedal, you ensure the throttle cable is adjusted properly.
Old 05-21-2006, 06:01 PM   #3
325iSBimmer
///MMMM VIDA
I think I understand what ur saying. when i had the mirror in behind and was looking at the back of the pedal I could see what looked like a litle tab, but it didnt seem to matter whether i pressed it in or pulled it out. But I'll trying removing it at the top first and then maybe I can bend it back far enough to use that little tab.
If I dont break this pedal is it ok for me to re-use it. whats the adjustment procedure for the throttle cable?
Thanks Justin!
UNDER CONSTRUCTION
Old 05-21-2006, 06:08 PM   #4
Justin e36
Justin e36's Avatar
You don't need a mirror to look at the back of the pedal. Take a look at it again from the front, it's a retaining clip. You have to remove the top before you can remove the bottom.
If you don't break the pedal you can reuse it... but 99% of the time, the clips will break. It's a part of the removal process really.. new pedals are cheap though, and come with new clips of course.
The throttle cable adjusts on a screw, same as under your hood.
Old 05-21-2006, 06:10 PM   #5
325iSBimmer
///MMMM VIDA
I guess I'll just add throttle pedal to the ever growing list of parts to get from dealer.
Thanks for the info.
UNDER CONSTRUCTION
Old 05-21-2006, 07:05 PM   #6
325iSBimmer
///MMMM VIDA
Justin, You wouldn't happen to have any good tips on how to completely remove the carpet?
UNDER CONSTRUCTION
Old 05-21-2006, 08:38 PM   #7
bimmer318ti
bimmer318ti's Avatar
Send a message via MSN to bimmer318ti
^ I had to cut my carpet about 2 inches in order to pry my gas pedal off. My gas pedal's clips also broke when I was taking it off
Visit " My Square One Condo " for all your Mississauga condo news
bimmer318ti is offline   Reply With Quote
Old 05-23-2006, 12:23 AM   #8
325iSBimmer
///MMMM VIDA
anyone else ever remove their carpets?
UNDER CONSTRUCTION
Old 05-23-2006, 05:39 PM   #9
WASABI
OG
http://rsiwerks.com/project332is/interior/
Old 05-23-2006, 05:51 PM   #10
Justin e36
Justin e36's Avatar
It's tough to do without removing your entire interior. I've removed a few of them. If you plan on installing a different carpet after, good luck. The stock carpet is moulded with different amounts of foam padding in different areas. (like to square out the hump in the center console.)
You need to remove the front/rear seats, entire center console. Create a 'slit' in the carpet around the gas pedal to slide the carpet off. Interior door sills, kick panels. You will have to use an x-acto knife and cut slits around the centre console and places under the kick panel unless you remove your dash. This can be siliconed back in place after as it would not be seen anyway.
