Old 05-17-2006, 08:06 PM   #1
nec
buying a z3
im planning on buying a z3 sumtime real soon. just waiting for the right one...i wanna get the 2.8 or 3.0.. what are the common problems i should look for when going to check the car out?
thanks
nec is offline   Reply With Quote
Old 05-17-2006, 10:36 PM   #2
crusher
OMGHI2U2
crusher's Avatar
Rear subframe.. Check that and have a mechanic look at it.. It is a common problem for this cars for the rear subframe to crack... My coupe has 111000km now and still no signs of the cracks.. Anyways, check out the link below it's mostly for the M Coupe but should apply some of them for the roadster.
http://www.maxbimmer.com/forums/showthread.php?t=33054
2013 Ford Focus SE
2011 Lincoln MKT
2003 Escalade 8 Seater of Fun - 251k and still running
Sold/Traded-in
2006 M5
2003 M3
2003 Civic Si
2000 M Coupe
1999 M3
1999 323i
crusher is offline   Reply With Quote
Old 05-19-2006, 11:11 PM   #3
jameswbl
where can you get the subframe fixed in Toronto?
thinking about preemptive fix...
jameswbl is offline   Reply With Quote
Old 05-20-2006, 12:16 PM   #4
crusher
OMGHI2U2
crusher's Avatar
I don't know anyone that does the subgrame fix in toronto besides replacing the subframe itself.. It looks like you can buy the reinforcement plates from Randy Forbes for 600USD and then have someone weld it for you. Or you can go to Randy he lives at Ohio which is not far from here.
Email him at Erandyforbes@aol.com and ask about the PDF outlines about the work he does.
PS: You will need a new LSD with dual ears..
Check the fix images here
Old 05-20-2006, 10:02 PM   #5
jameswbl
thx Bruce...
yeah I talked to Randy...turns out minimally I will need new exhaust (the stock wont clear the duel ear), new/mod speed sensor wheel in diff and the dual ear diff cover...read: lots of $$$ and makes my coupe undrivable for at least 2 mths
and it affects the crumble zone...very bad for rear end collision...
