Old 05-15-2006, 05:36 PM   #1
Domvr6
s50 or s52 cams
is there any difference in power between the two sets of cams when putting into an M50? what chip would go the best with the cams?
Domvr6 is offline   Reply With Quote
Old 05-15-2006, 08:39 PM   #2
Rampage
Rampage's Avatar
You can only put the S50 cams into a M50, and likewise only S52 Cams in a M52.
You will need a chip though, I cant remember who sells them (Eurosport or Turner maybe?) or get something custom
2009 328i 6-spd - AW - Oyster Dakota - Sport Pkg. - Prem Pkg.
Rampage is offline   Reply With Quote
Old 05-15-2006, 11:21 PM   #3
JazzM
Why can't you put the S52 cams in a single vanos M50?
According to VAC and turner the S50/S52/M50/M52 single vanos North American motors all share the same camshaft design and the camshafts are interchangable. (http://www.vacmotorsports.com/cgi-bi...pl?item_id=454)
T.
T.
Old 05-15-2006, 11:57 PM   #4
Domvr6
yeah i thought both could be used in the m50 motor. i was just curious if there is any difference in using either or in the m50.
Old 05-16-2006, 09:25 AM   #5
JazzM
S50 and S52 cams are different lift and duration. I believe the S52 ones are more aggressive.
T.
T.
Old 05-16-2006, 10:21 AM   #6
Domvr6
so with getting the s52 cams i could probably end up with better results in power
Old 05-16-2006, 10:23 AM   #7
JazzM
Yes, the goal with more aggressive cams is to give you more power on the top end.
T.
T.
Old 05-16-2006, 12:42 PM   #8
thinair
moderationistismingly
thinair's Avatar
Actually the 3L cam will fit the 2.5L, 2.8L and 3.2L, but the 3.2l cam will only fit the 2.8L. Something to do with counterbalances no clearing the cam rack. Basically if you swap the cam rack with the cam, an S52 cam will fit in an M50 head.
And JazzM, I've heard the opposite, the S50 cam is slightly more aggresive.
Old 05-16-2006, 07:58 PM   #9
Rampage
Rampage's Avatar
Sorry if thats wrong information, but that is what Ive read from bf.c
seems like I almost had it
Old 05-16-2006, 10:26 PM   #10
JazzM
Yeah looks like due to the counter balance the S52 cam will not clear the M50 cam rack. It also appears that the S52 cams are hollow as opposed to the S50 ones being solid.
Havn't seen any TIS numbers regarding lift and duration yet.
You can put the S50 cams in both the 2.5,2.8 and the 3.2.
T.
T.
