Old 05-04-2006, 09:11 PM   #1
Andy E34
Registered User
Andy E34's Avatar
Send a message via MSN to Andy E34
Angry HELP, Ignition switch is on its way out
At first the ignition seemed a bit stickey...now (a few weeks later) we have to crank the steering wheel back and forth to get the key to turn in the ignition...4 me, I deal with it...my wife...not so much! Just got back in from the driveway to help my wife start the car...yea this is gonna work
I remember a reference to steering lock delete or ignition delete or push button start..., or something like that due to regular failures of the key switch...and a min. $400.00 repair???...so I did a search and could not find a DIY post.
Justin I know you have a push button start, is that for ignition switch reasons or because its cool to have?
Anybody else have this problem & how did you fix it?
Andy E34 is offline   Reply With Quote
Old 05-04-2006, 09:16 PM   #2
Soldo
Soldo's Avatar
I have a push start in my car, cause one day i turned my car off, pulled the key out, but the motor was still running. The car was stuck in the ON position, so now i run it off a push start. Its a big pain in my ass, and i still need to put the key in the ignition in order for the car to start!
Not worth it, try to get it fixed properly!
Keven Soldo
Old 05-04-2006, 11:37 PM   #3
Justin e36
Justin e36's Avatar
Andy... the ignition tumblers were defective from 92-94. They would stick on the ignition position even after the car has started, which will quickly burn out your starter.
You'll need a new ignition lock, which unfortunately means a different key too. (unless you go through the dealer). I have replaced my ignition and door locks, not because my old ones were broken... only because I don't want my keys to match my VIN. Never know who made a copy in the past.
I do have a lighted start engine button as well, it's not a hassle at all for me... I find it convenient actually. But I can still start the car using the traditional method as well. (just in case something goes wrong with my wiring, I won't be left stranded). I wired up the push button start partially because I know my 92 ignition is defective, and it was sticking.. and partially because it's a nice little mod to have.
Old 05-05-2006, 12:59 AM   #4
Soldo
Soldo's Avatar
I've always wanted a push button, but the fact that my car is STUCK in the on position and the car thinks the key is in the ignition at all times is a real pain in the ass..... as soon as you open the door, it begins to chime!!
Keven Soldo
Old 05-05-2006, 07:19 AM   #5
Andy E34
Registered User
Andy E34's Avatar
Yep...that chime is driving me crazy!!!
