Old 05-03-2006, 09:44 PM   #1
BennyL
7th Gear Member
BennyL's Avatar
Angel Eyes Wiring possibility?
Hey guys,
I was wondering if someone could shed some light on this idea...
I wanted to maybe route the angel eye wires to the switch on the dash for the rear fog lights.
What would need to be done to do this?
I figure, since there's a hole for that switch, and I never intend on actually having rear fog lights, why not run the wire to there?
Any input?
I'd obviously need the switch itself, from the dealer. What else? How hard would it be?
Old 05-03-2006, 10:06 PM   #2
Big T
94 318is
It would be much easier to get a push button switch from radio shack, drill a hole there and wire it up. MUCH easier
Big T is offline   Reply With Quote
Old 05-04-2006, 11:36 AM   #3
Nascar318is
Nascar318is's Avatar
Do a search, I think Justin did this with his E36? I'm not sure but almost positive, he had another switch in the car just for the angel eyes. Check with Aziz as well on his E46, he has a switch just to turn on his angel's...
Old 05-04-2006, 12:34 PM   #4
BennyL
7th Gear Member
BennyL's Avatar
well, im hoping justin will answer here, because i assume he has done something similar. and i know he plans on doing the rear foglight conversion on his car, so he probably knows more about how that switch is wired up.
Old 05-04-2006, 01:37 PM   #5
Nascar318is
That would be great. Also I'd like to know how to hook up my headlights so they are not on all the time...
Old 05-04-2006, 03:44 PM   #6
Justin e36
Justin e36's Avatar
Rear foglight button to turn on/off angel eyes? You're a bit late.. Razcal has the switch and has already started doing the exact same thing. Yes, it's possible to do.
You'll need the switch, harness, automotive relay, and a bit of wiring know-how to do this.
My angels are hooked up to a relay, I wired them up differently. I have other switches mounted in my car to do other things.. (fold the mirrors, start engine button, brake light kill switch, etc.)
Nascar - depends on the year of your car, it could be as simple as swapping out your daytime running lights module, or it could be a little more complex as wiring up a separate headlight switch.
Old 05-04-2006, 03:51 PM   #7
BennyL
7th Gear Member
BennyL's Avatar
justin, did you say Razcal is doing this exact same mod?
does he have an E36 or an E46?
Old 05-04-2006, 04:08 PM   #8
Justin e36
Justin e36's Avatar
e36.
Old 05-04-2006, 06:25 PM   #9
BennyL
7th Gear Member
BennyL's Avatar
do you mean Razkal 320i
Old 05-04-2006, 07:13 PM   #10
BMWFORLIFE
Technoviolet Shifting
Justin you have a push button start thats prettty cool
BEEEEEEEE EMMMMMMMM DOUBLEUUUU
BMWFORLIFE is offline   Reply With Quote
Old 05-04-2006, 07:54 PM   #11
Nascar318is
^^ A Z8 Push start button where his cigarette lighter was
Justin: It's a 94
Old 05-05-2006, 09:24 PM   #12
superman123
slushbox champion
just tie it into your font fog lights
i have angel eyes and thats what i did ..but then again i dont have any fogs (have a hamann front bumber )
easiest way to do it
superman123 is offline   Reply With Quote
Old 05-06-2006, 12:31 AM   #13
RMPMOTORS
RMPMOTORS's Avatar
I just installed the euro foglight switch for the angel eyes operation.
Benny I can install and wire that in for you.
Rocco
www.RMPMOTORS.com
www.Facebook.com/RMPMotors
RMPMOTORS is online now   Reply With Quote
