Old 05-03-2006, 06:46 PM   #1
dmako
Deal no deal turns into deal Got my 528i
Deal no deal, no deal turns into deal
My thanks to all who replied to my questions. Now get ready for some real questions. Hope to pick up in a few weeks.
Details:
BMW 528i '99 - black, 4 door sedan, sport package, moonroof, 5 speed, 1-owner, new tires, serviced by dealer, 102,000 miles. Never driven in winter, garages. Highway miles. CT to Fla. $11,500.
dmako is offline   Reply With Quote
Old 05-03-2006, 07:11 PM   #2
honestly bro, coming from a postwhore this actually means something. You dont NEED to start a new thread every time you want to ask a question, you already have 3 threads aobut what cars your gonna buy
528 looks good, my m52 has that many miles on it, runs storong
good luck!
Old 05-03-2006, 07:13 PM   #3
dmako
Understood
Understood, thanks for setting me staight.
Old 05-04-2006, 09:19 AM   #4
O.S.
O.S.'s Avatar
congratulations and enjoy!
F10 535xi M-Sport, Dark Graphite
E39 540i Sport Titanium Silver - SOLD
E34 520 Black - SOLD
O.S. is offline   Reply With Quote
Old 05-04-2006, 10:51 AM   #5
crusher
OMGHI2U2
crusher's Avatar
congrats on your new ride.. post some more pictures of your rims they look deep dish like the one that came with the 540's..
crusher is offline   Reply With Quote
Old 05-04-2006, 12:22 PM   #6
BMWags
BMWags's Avatar
miles or kilometers?
Old 05-04-2006, 02:35 PM   #7
Darkness95m3
Darkness95m3's Avatar
Originally Posted by dmako
102,000 miles. .
^^Miles^^
Old 05-04-2006, 06:52 PM   #8
dmako
Thanks much, will also keep post to single topics, mostly help on topics.
Pics will be posted, hopefully in 5 - 7 business days, waiting on funds.
PS: pic was taken with camera phone.
Basicly a bit early (months) 50 year birthday gift to my self, can't afford new. Will drive in the spring, summer, fall months.
Depending on he full in$pection$, I'd like to add something to make it sound a bit better, nothing drastic, just a bit more sporty.
Old 05-04-2006, 07:46 PM   #9
suger ray
nice car enjoy
suger ray is offline   Reply With Quote
Old 05-05-2006, 09:05 AM   #10
O.S.
O.S.'s Avatar
very nice gift!
I got mine 1 month early for my birthday too . a gift to myself
Old 05-05-2006, 05:30 PM   #11
dmako
so much to learn
Originally Posted by O.S.
very nice gift!
Just starting to hear about this CDV, starting to look into it's removal. As far as removing the CDV, did you do your self? Seems easy up to a point.
Also it seems some remove, while some replace. Any comments on removal vs. replace?
Old 05-06-2006, 12:39 AM   #12
O.S.
O.S.'s Avatar
since your car is off warranty you can just remove the CDV. it is a simple procedure but I did not do it myself. My mechanic did it when he installed my exhaust and short shift kit.
the short shifter, cdv remove, clutch stop and the tranny fluid change are the first things one needs to do. they are a must IMHO. once you've driven with these things done - you can not go back.
Old 05-06-2006, 11:24 AM   #13
dmako
Clutch stop?
This is *great* info!
Can you expand on the clutch stop mod?
Old 05-06-2006, 07:16 PM   #14
dmako
As far as clutch stop ...
Does the clutch stop limit the travel of the clutch pedal towards the firewall? If so, great as the clutch pedal does seem to have a long throw.
Where/how does this clutch stop mount? In the car, linkage?
Old 05-06-2006, 07:30 PM   #15
dmako
Even more info on a clutch stop i.e. homemade
I found this info which seems to answer my questions. Wonder if it'll work on a E39?
http://forum.e46fanatics.com/showthread.php?t=206363
Ok so after reading all these threads about clutch stops I decided to give it a shot... I have an 01 325xi (sedan) so I don't know how many other applications this will work PERFECTLY for but it should work on all begining E46's til mid 01 in the sedans. (the coupe may be a little different but not much and the post-mid 01's I don't know how much play you have with the magnetic switch so you should experiment a little). I ran to Lowes right by
work and played around for about an hour on my lunch break until I finaly found the perfect things. You need 2 parts, no glue, and less then 30 seconds install time. Part #1 is in the drawers with all the other bolts, its called an "Elevator Bolt" 3/8" x 1 1/2" it is blackish in color (price $0.97). Part #2 is a few isles over in the adhesive bumpers for furniture, its called "Grippers" 1 1/2" Self-Stick the part # is "7384" from SoftTouch (price $3.04).
The grippers package has 8 little discs in it so you can make 8 clutch stops
Assembly: Take elevator bolt out of package. Take 1 disc out of package. Remove sticker covering adhesive from disc. Center disc on elevator bolt and press on.
Installation: unscrew your factory clutch stop by hand (the black thing behind your clutch pedal on the floorboard). Screw in your newly assembled one all the way (just hand tight you don't need to wrench tighten it it isnt going anywhere)
You're done. No glues, no mess, etc. This setup is the perfect height, it doesn't require any adjustment of the clutch switch for the ignition (my car doesn't have cruise so can't test that obviously). The best part about this is it looks a lot more professional then most of the homemade ones i've seen pictures of on these boards. Enjoy.
Being less then $5 and less then 30 seconds of install time (and probably less then 2 minutes of shopping time now that I told you all the part numbers) you should have NO reason to not go do this right now... I was kinda skeptical but this has been the best mod for the money anywhere.
