Old 05-01-2006, 03:38 AM   #1
Jon@Bimmersport
Jon@Bimmersport's Avatar
Suitable Turbos for my application...
Well i am considering going the FI route, i want to go with a custom kit though. I wanna start buying things so hopefully by winter i can install it.
I have a really good deal on a brand new turbo, the specs are:
GARRETT INTERNALS T3/T4 T04"E"
. 50 A/R COMPRESSOR
.63 A/R TURBINE
.57 TRIM
5 BOLT EXHAUST FLANGE
WET FLOATING BEARINGS
COMPRESSOR HOUSING A/R RATIO .63
OIL COOLED
SPOOLS HARD, AND SPOOLS FAST!
WASTEGATE SPECS:
BRAND NEW IN THE BOX 40 MM WASTEGATE,
WITH ADJUSTABLE BOOST CONTROLLED SPRING
10 Psi TO 18 PsI
Now would this be a good turbo for a 2.5non vanos motor? What would the power delivery be like? I dont plan on going higher than 8-9psi. Would this turbo flow all the way to redline or would it max out as well? I would want something that doesnt lag too much, but hits hard and hard all the way until redline (7000rpm). What do you guys think? Also...are turbos with V band flanges better than the standard 5 bolt exhaust flange? What are the benefits etc, accessibility or easy removal? Also...where can I get a custom manifold made along with mandrel bent piping done?
Old 05-01-2006, 07:25 AM   #2
paul
just go with a gt35r, i check the specs on mine
paul is offline   Reply With Quote
Old 05-01-2006, 12:40 PM   #3
_DIESEL_
_DIESEL_'s Avatar
The specs that you posted are the same specs on my turbo
turbo is good up to 400 hp. On your motor you would max out that turbo between 15 and 17 psi max. For 8 or 10 psi it'll flom well all the way to red line
_DIESEL_ is offline   Reply With Quote
Old 05-15-2006, 03:37 PM   #4
Big T
94 318is
That was the exact turbo I was looking at for a m50 that I don't have yet.
Looks like a good choice to me.
Big T is offline   Reply With Quote
Old 05-15-2006, 03:47 PM   #5
JMW
Pole busted to boosted.
JMW's Avatar
i need turbo in mine to...or s/c.,.so the info u gave was good...cause mines gunna begin to be worke don in winter as well...how much thios costin u around?
-neil
Official Team BIMMERSPORTAUTOMOTIVE vehicle owner.
support: thanks to. Bimmersport automotive and audio 2 go (ATG motoring)
Originally Posted by junaid
"i saw your car there when i was there a few weeks ago, looks absolutely stunning man. I think i popped a ****ing boner, that paint looks sick
JMW is offline   Reply With Quote
