Old 04-30-2006, 06:05 PM   #16
RumRogerz
RumRogerz's Avatar
i think a 330i upgrade looks more easier from what you described. Are the 330i and m3 brakes similar in breaking power?
Always and never are two words you should always remember never to use
RumRogerz is offline   Reply With Quote
Old 04-30-2006, 09:51 PM   #17
thinair
moderationistismingly
thinair's Avatar
They're very similar in braking power, the M3 front rotors have a bit more mass to absorb heat, but aside from that they're the same. Now that I think of it, you MAY need a master cylinder swap on the 330i brakes as well if you do the front and rear.
Old 05-01-2006, 11:32 PM   #18
RumRogerz
RumRogerz's Avatar
ive been doing more reading.
it seems like the 3.2 evo has vanos issues. and its a double vanos unit at that. The repairs on that unit ain't cheap.
so now im totally contempating on what to do
Old 05-01-2006, 11:57 PM   #19
just go with retarded boost on your m50
Old 05-02-2006, 12:24 AM   #20
RumRogerz
RumRogerz's Avatar
will i need to convert to obdi for this drop?
Old 05-02-2006, 09:06 PM   #21
thinair
thinair's Avatar
The S54 also had double vanos as a note. Anything can go wrong on any engine, it's a chance you take.
Old 05-02-2006, 09:27 PM   #22
windsor318is
Nitrous Junkie!
windsor318is's Avatar
does the evo motor with 321 hp OBDII??? does it need to be converted to OBD1 for any reason??
Old 05-02-2006, 10:47 PM   #23
thinair
thinair's Avatar
Yes, it's 321hp in stock form, and yes it's an OBDII engine. It can be converted to OBDI, but I can't imagine spare OBDI S50 wiring harnesses and ECU's being all that common on their own.
Old 05-03-2006, 05:37 AM   #24
Darkness95m3
Darkness95m3's Avatar
Forced Induction.
Old 05-03-2006, 01:45 PM   #25
BennyL
7th Gear Member
BennyL's Avatar
2 newbie questions:
what are floating rotors?
whats so good about ODBI, that everyone switches to it?
Old 05-03-2006, 02:19 PM   #26
mirek
mirek's Avatar
Floating Rotors: http://www.wildwestcycle.com/f_disks.html
OBD2 has alot of stuff done to limit emissions, has more o2 sensor, etc. OBD1 is more tunable.
