Old 05-04-2006, 12:33 PM   #76
_DIESEL_
_DIESEL_'s Avatar
Originally Posted by paul
nope my headgasket went, but thats the name of the game with bmws. Just ask cardcounter how many he has blown, i wont even sy the hp i ran at 30psi, u can ask tony...........
He only blew one and it was at 32psi plus he was running a 3.2l headgasket 87mm bore insted of the 85mm. but it does not matter all i said that is hard to bolieve that it can make that power at 10 psi because M3 barly make that power at 10 psi. I don't know whats so special about your motor you won't post up what's done to it or share any info. I can say right now my setup that i have right know and my 2.8l motor will not make not even close to 360whp at 10 psi and i'm running a full stanalone P8PRO no chip bs.
_DIESEL_ is offline   Reply With Quote
Old 05-04-2006, 12:40 PM   #77
_DIESEL_
_DIESEL_'s Avatar
Originally Posted by b_w.
what kind of setup do you have? i thought i read on bf.c that you you have the audspeed kit?
Yes i got that kit but had to fabricate alot of thinks to fit runnig only half of that kit manifold turbo and the pipes everything else has been changed.
Old 05-04-2006, 12:50 PM   #78
paul
What comp r u running?
Also I know about what kind of headgasket he was using i was using the sameone at one point...
paul is offline   Reply With Quote
Old 05-04-2006, 01:11 PM   #79
_DIESEL_
_DIESEL_'s Avatar
My compression is 10.2.1
I just did a calculation on your motor if you rev your motor to 7000 rpm at 10 psi with the head to flow 100% VE you can get 358 whp I guess that 2.5L head flows really good stock or its modded . but to get to 100 % with boost is hard
My motor if i could get the head to flow 100% it would make 401 whp at 10 psi but i already know that's not gonna happen since other people try it like cardcounter he dynoed 478 at 18 psi and it comes out the head flow is close to 100 % and his head is not stock.
Old 05-04-2006, 01:12 PM   #80
fukenricen
fukenricen's Avatar
well paul i dont know if i have the hp at highboost but i do have the 400torque on cam since i think we were just mesuring the torque on the car.
KEEP IT SIMPLE,KEEP IT JDM
wooooooo woooooooooo
AntiRice
11.0@130mph
fukenricen is offline   Reply With Quote
Old 05-04-2006, 02:55 PM   #81
_DIESEL_
_DIESEL_'s Avatar
Paul
Is this your setup that ur running now i just saw this in the boosted check in forum
new setup
3.2 m3 engine converted to obd1
gt35r turbo
AA Manifold
AA stage 2 intercooler
custom 3'' ss turbo piping
custom 3'' ss v band exhust
greddy type s bov
turbosmart 35mm waste gate
AA water injection
550 injectors
areomotive fuel reg
2 external fuel pumps running off a external sump mounted under the car
stock in tank fuel pump
custom fuel rail
euro oil cooler with b&m oil cooler
clutch masters stage 4 clutch
1.40 headgasket
arp head studs
greedy boost controller
hks turbo timer
tec 3 r full standalone
custom motor mount
wide band
This would make alot of sence
Old 05-04-2006, 03:33 PM   #82
paul
and more i have changed alot. that headgasket is on the 3.2 motor not the non vanos motor
Old 05-04-2006, 09:20 PM   #83
_DIESEL_
_DIESEL_'s Avatar
Nice setup i guess your going for high numbers.
I'm getting the same headgasket i need more boost.
what was the highest boost you ran on your motor on pump gas
Old 05-04-2006, 11:23 PM   #84
b_w.
Hell no audspeed kit, And my motor is a 2.5 NON VANOS. Read up on what that motor can do then comment,
i did not mean you, but the other guy with the turbo 325.
b_w. is offline   Reply With Quote
Old 05-05-2006, 07:15 AM   #85
paul
30psi only a hand full of times
Old 05-06-2006, 09:07 AM   #86
_DIESEL_
_DIESEL_'s Avatar
I can't bolieve that these motors can take this much boost.
Did you do anything to your head or you left it stock. and if you don't mind pm me the numbers at 30 spi this number scares me.
Old 05-06-2006, 10:32 PM   #87
b_w.
or he could just post the dyno graphs
Old 05-07-2006, 02:24 PM   #88
_DIESEL_
_DIESEL_'s Avatar
That would be nice
