Old 04-22-2006, 01:16 PM   #1
bimmer318ti
bimmer318ti's Avatar
Send a message via MSN to bimmer318ti
Where to get angle rings
I burned 2 of my rings and I need a pair. Anyone know where I can get them. (prefare locally) I know ebay has like 4 of them for $70 us. Maybe some else need two rings and we can buy a set and split it.
Visit " My Square One Condo " for all your Mississauga condo news
bimmer318ti is offline   Reply With Quote
Old 04-22-2006, 01:46 PM   #2
BMWF1
Guest
Posts: n/a
how do u burn 2 rings?? did you burn the LED Lights inside the rings? cause those are like 2 dollars to replace and you don't need to change the actually ring, most people have this misconsecption
Old 04-22-2006, 02:09 PM   #3
bimmer318ti
I think I touched a postive and a negative end togther by accident. When I connect the ring directly to the battery - nothing happens. Where can I ge the LED lights ?
Old 04-22-2006, 02:37 PM   #4
Jon@Bimmersport
Jon@Bimmersport's Avatar
LED lights, bmwF1 this isnt DDE lol.
You have CCFL? you burned the wire that lights up rght? you need the wire...not the plastic ring it clips into...electric surplus or something like that downtown shoudl have this wire, they have almost every fibre optic cable there. just make sure its plastic insulated so water wont affect it.
Old 04-22-2006, 03:02 PM   #5
bimmer318ti
any one have the phone number for those guys? how much am I looking to spend? could I get them like in 7000k instead of 6000k?
Old 04-22-2006, 04:28 PM   #6
Justin e36
Justin e36's Avatar
you don't need LED bulbs, you have CCFL rings. BMWF1, both rings are connected to a single transformer, this is why both of them blew.
swapping the + and - wires will not blow the rings, there is an inverter inside the transformer. even if you have a very cheap angel eyes set which doesn't have an inverter in the transformer, the rings themselves will still not blow.. the inverter will.
the rings can NOT be directly connected to a 12V power supply without the transformer & igniter, it will simply not work. It will also not blow the rings if touched for a short period of time.
disconnect your working angel eyes from the transformer, and plug in your 'dead' ones, see if they work or not. this is what the transformer looks like:
Also, the name of the store is Active Surplus. There is no point in calling them to ask if they have what you need.. it's basically a warehouse of electronics parts... everything the home hobbyist could possibly ever want or need, very inexpensive... but they'll be clueless if you ask them for parts for CCFL angel eyes, it's not their language. If however you told them you needed a double pole double throw momentary off momentary switch... they'll point you right to it. You'll more or less have to go there already knowing what you need, and will have to find it yourself. www.activesurplus.com
Old 04-22-2006, 05:01 PM   #7
bimmer318ti
Thanks a lot justin. I will try what you told me in a hour or so. Is it possible to buy the inverter? is so where and how much?
Old 04-22-2006, 05:02 PM   #8
$500bimmer
im goin there!
Old 04-22-2006, 05:24 PM   #9
Justin e36
Justin e36's Avatar
yeah, or you can build one... active surplus, ebay.. even umnitza should have them. Find out if the transformer is dead first... if it is, then take a picture of it and any writing on it and post it up.
Old 04-22-2006, 05:24 PM   #10
Justin e36
Justin e36's Avatar
Originally Posted by $500bimmer
im goin there!
don't park outside.. or you'll end up with a $60 ticket like me.
Old 04-22-2006, 06:22 PM   #11
bimmer318ti
Justin you were right. My rings are ok .. you saved me $$$ thank you - I owe you a beer
On the inverter there is a sticker which says:
model F12-138-2bm
PRI 12v-13.8v m.7a max
SEC load CCFL lamp 3w 2pcs
under the sticker it says basicly the same thing with "racing rash"
edit: one of the rings dont work.. meh I'm stuck with 3 rings. The transformer is teh same one as you posted.
Old 04-23-2006, 04:27 PM   #12
bimmer318ti
where is the best place to get the trasformer and the ring localy.
Old 04-23-2006, 05:09 PM   #13
Nascar318is
Nascar318is's Avatar
Same problem here, one of them is toast, tried the other plug and nothing, tried the other 2 plugs on the inverter and nothing...
So I just need one ring, sucks man didn't even have them installed 2 hours....
Old 04-23-2006, 05:15 PM   #14
bimmer318ti
LOL.. sell me one of your rings.. and buy new ones on ebay. or I sell you one of my rings and get new ones
Old 04-23-2006, 05:18 PM   #15
Nascar318is
Sure^^ Tell me how much you want for one of your rings.
What about if M3ti_Compact sold us 2 of his rings? i don't hink he's installing his..
http://www.maxbimmer.com/forums/showthread.php?t=69422
