Old 04-11-2006, 03:22 PM   #1
just325iS
Blown Seals
I have been having issues with blowing my seals on my V2S. At first I thought it was due to my track driving but now I've found out my problem. I thought this might help others in the future.
My seals went because my crankcase valve wasn't working so it wasn't releasing the pressure in the intake. This pressure is what caused my seals to blow. So you might want to consider changing this part for peace of mind.
just325iS is offline   Reply With Quote
Old 04-12-2006, 12:16 PM   #2
sloveniaboy
sloveniaboy's Avatar
what seals blew?
Old 04-12-2006, 02:04 PM   #3
just325iS
the one before the impellers
Old 04-12-2006, 02:10 PM   #4
sloveniaboy
sorry, didn't realize you were talkin bout the charger unit itself, I thought you were reffering to seals blowing on the motor
Old 04-13-2006, 06:52 AM   #5
SickFinga
SickFinga's Avatar
so your theory that Vortech blowers had poor reliability was wrong?
That's good news to hear.
Old 04-13-2006, 01:00 PM   #6
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
Hold on, you have the blower pressurising your crankcase? Get that fixed ASAP or you'll be buying a new motor.
Old 04-13-2006, 01:04 PM   #7
just325iS
yeah, because I was getting really fustrated with the power loss. I hope it will run good for me this time around. Really miss going to the race track. Haven't been to the track since I replace all my bushings with aluminum ones. I know that it made a huge difference but haven't really gotten a chance to test them out in the heat of battle.
Old 04-13-2006, 01:11 PM   #8
just325iS
yeah, I'm on that right now Axxe. It wouldn't matter anyways, I've got so fustrated trying to figure out the problem that I went and bought myself a Ducati 999. The bimmer could sit around all summer and I wouldn't care anymore. It will be finish soon though. Got to run all stainless steel fuel lines with high flow filter, put in the cams, install the alcohol injection, get Mark D to burn me a new chip, get the fenders cut to fit 265/30/19's at the rears and get the car corner balanced. Oh, the rear big brakes are just in, so will have to pick that up and install that too. I think that's it for now.
Old 04-13-2006, 04:21 PM   #9
Axxe
Axxe's Avatar
Alright, just wanted to make sure you knew the gravity of the situation. JazzM blew his supercharged 2.8 motor like that.
Old 04-13-2006, 09:57 PM   #10
just325iS
shit, didn't know that's what happened to Tom's motor
Old 04-13-2006, 10:21 PM   #11
Furious
BMW again.
Furious's Avatar
guys is there a way to know/check that you could be boosting your crankcase?
Old 04-14-2006, 12:13 AM   #12
Axxe
Axxe's Avatar
Well, you can look for the crank case ventillation tube, and check if it's still connected to the intake manifold. Or you can open your oil cap, and rev the motor up, if you have air coming OUT at a high speed/pressure, it's likely you have a pressurised crank. If it's not boosted, when you rev it up with the open cap, nothing funny should happen.
Old 04-14-2006, 10:05 AM   #13
Furious
BMW again.
Furious's Avatar
thank you i will give it a look see
Old 04-14-2006, 12:07 PM   #14
SickFinga
SickFinga's Avatar
Btw, that what blew Randy's engine too.
Mark, if I were you I would go or call RMP and verify if they did it.
It is described in the AA Manual.
In fact I'm going to RMP as soon as I take my car out just to check if I'm boosting my crankcase.
Old 04-14-2006, 05:48 PM   #15
Axxe
Axxe's Avatar
Yeah Vlad, you should since you're complaining of low power, which could be due to piston rings that are messed up. You should test the compression on your motor ASAP to make sure the problem isn't in the motor.
