Old 04-09-2006, 12:41 AM   #1
Magic_Black
BMW ID Designer
Magic_Black's Avatar
Clifford Matrix RSX 3.5 2-Way Security System / Remote Start System with Responder Te
BRAND NEW - NEVER USED
6-channel remote start/security/keyless entry system
Confirms commands and system triggers on the transceiver LCD screen
Clone-Safe® Code-Hopping®
Parking Light Flash
Failsafe® Starter Kill
Anti-Grind
Dual Zone Shock Sensor
Six-Tone Siren
Super Bright LED System Status Indicator
Miniature XCRS (Extreme Capacity Relay Satellite)
Defroster Output
Built-in Turbo Timer
4 Auxiliary outputs
Dome Light Supervision
Comfort Closure
Horn Honk
Includes One 2-way Responder Transceiver
*Package includes everything that came in the box originally.
Retails for 599.99$ US.
Asking 400 Canadian
Very Reliable Vehicle Security System.
For more info:http://www.clifford.com/matrix/responder/default.asp
Magic_Black is offline   Reply With Quote
Old 04-09-2006, 10:00 PM   #2
Magic_Black
BMW ID Designer
^^bump
Old 04-10-2006, 04:06 PM   #3
uber e36
uber e36's Avatar
The website notes that this is only for an automatic. Is this true with your unit?
Daily: '06 S4
Wife: '05 X5 4.4i
Fun: '95 325is
Old 04-11-2006, 12:52 AM   #4
Magic_Black
BMW ID Designer
no, it will work for a manual car as well.
The only thing is that if you left your car in gear it will start, but then shut off.
the alarm does not have the feature that can sense if the car is in gear or not, like more expensive remote starter system.
So you have to remember if you left it in gear or not.
Old 04-12-2006, 02:12 AM   #5
Magic_Black
BMW ID Designer
^^bump
Old 04-13-2006, 03:12 AM   #6
Magic_Black
BMW ID Designer
Wicked Alarm System.
Someone has to take this.
Retails at best buy for 430$ plus tax.
Old 04-13-2006, 03:35 AM   #7
Ital_325i
Lost in a world of Chaos
Ital_325i's Avatar
Does anyone know how much it would be to install?
Ital_325i is offline   Reply With Quote
Old 04-13-2006, 05:01 AM   #8
Justin e36
Justin e36's Avatar
install will run around $400-$600 CDN, depending on which shop does the job. Most shops will just charge hourly, depending on how much work needs to be done. Honestly, though it's a long process (only because you have to dismantle so much of your vehicle to wire up the brain, sensors, and antenna), but it's not difficult to do yourself.. I'd recommend giving it a shot, instructions are very easy to follow, just need to get a wiring diagram for your car. (haynes or bentley manuals.)
Old 04-13-2006, 08:14 AM   #9
A.K.A. Blackout
BLACKOUT
A.K.A. Blackout's Avatar
I have the same unit in my car with the remote starter. It is pretty sweet, and the remote starter still works after the conversion to 5 speed, but you have to remember to keep the car in neutral which I am not use to. I got it done at Best Buy, and they took the full day to hook it up, but they won't install the remote starter on Manual cars. Bump for sweet alarm
A.K.A. Blackout
A.K.A. Blackout is offline   Reply With Quote
Old 04-13-2006, 10:22 AM   #10
Magic_Black
BMW ID Designer
Thanx for the Bumps!
at bestbuy it costs 600$ plus tax to buy and install.
If you are good with your hands you should be able to install it yourself, also if you have a day to play around with your car you'll probably get it done.
I have done alot of wiring and exploring in my e30, and if something happens to it with the experience i have now i am sure that i can adjust or fix it myself without taking it someone that will cost me an arm and a leg.
Old 04-15-2006, 04:06 AM   #11
Magic_Black
BMW ID Designer
^^bump
Old 04-19-2006, 01:02 AM   #12
Magic_Black
BMW ID Designer
Still for sale, now asking 370 canadian for the entire system.
Your saving 125$$$
if you had bought this system brand new from Bestbuy it would be costing you abot 495$ including tax.
Someone has to take it.
Offers are also being tolerated.
