Old 04-08-2006, 10:14 PM   #1
Chris de la Cruz
sex, drifting & punk rock
e34 540i 6speed
I guy offered his car to me for cheaaapp. 360 000 kms on the motor and alot of surface rust and dent on the passenger side . its a 94 540i 6speed. i was damn interested to get it as a dd or a new project. any inputL?
www.CSCS.ca
Old 04-08-2006, 11:46 PM   #2
Paul540/m3
BMW Individual
Send a message via MSN to Paul540/m3
Those are rare, esp 6speed. But watch out for nikasil (although not sure how much life is left in that motor anyways lol) But def a fun car
Paul540/m3 is offline   Reply With Quote
Old 04-09-2006, 12:14 AM   #3
Chris de la Cruz
i just did an oil change on it today at work and the customer was willing to give it away for cheap... seals have been replaced and the bushings all been done
www.CSCS.ca
Old 04-09-2006, 02:40 AM   #4
Gamite
Gamite's Avatar
do a compression check before you buy. Paul is right, it could be suffering from the ol nikalsil problem. Engine could be defunct
www.gamite.net
Old 04-09-2006, 10:32 AM   #5
Chris de la Cruz
can anyone shed mnore light on the nikalsil problem?
www.CSCS.ca
Old 04-12-2006, 11:47 PM   #6
Chris de la Cruz
anyone?
www.CSCS.ca
Old 04-12-2006, 11:50 PM   #7
how much, give me it!
Old 04-12-2006, 11:51 PM   #8
Chris de la Cruz
talk to me on msn about it...
i did a search on google.. i got it
The BMW M60 V-8 and BMW M52 6-cylinder engines (the M52 Nikasil engine never went to the USA) with Nikasil cylinder bore linings are particularly vulnerable to fuel (gasoline or petrol) with a high sulfur content.
The sulfur in the fuel breaks up the Nikasil lining in the cylinders, thus causing a loss of compression. Once the lining is damaged, excessive bore wear of the soft, underlying alloy occurs very quickly. Some Nikasil engines have failed in as little as 30,000 miles. And the effect is cumulative, so if the engine has ever been run on high sulfur fuel, the damage may already have been done and premature bore wear may result.
Some symptoms of the Nikasil problem are rough running at idle and difficult cold starting, both due to loss of compression. In severe cases, the loss of compression is so bad that the engine loses power. Oil consumption increases dramatically as oil is sucked up the side of the leaky pistons. In extreme cases, the compression decrease is so severe the car will not start in cold weather, especially M52 6-cylinder engines.
Over the years, BMW has provided replacements with steel, cast-iron or Alusil lined engines, at considerable cost to the manufacturer. Often, disgruntled owners have borne the brunt of these replacement costs, and prospective buyers are at risk, too.
www.CSCS.ca
Old 04-22-2006, 11:07 AM   #9
the bachelor
So? Did you buy it yet?
Faster Than A Speeding Ticket.
the bachelor is offline   Reply With Quote
Old 04-22-2006, 11:11 AM   #10
Soldo
Soldo's Avatar
How much is he fivinc it to you for?
Keven Soldo
Old 04-22-2006, 09:14 PM   #11
Chris de la Cruz
i took a look at last week, and honestly its too much work to get it running/ looking up to my standards
www.CSCS.ca
