Old 04-03-2006, 09:24 PM   #1
Stuttgart
Bmw = Bought My Wife
Stuttgart's Avatar
Send a message via MSN to Stuttgart
y doesn't the tranny go all the way?
I am putting my tranny back onto the engine and it wont go all the way to the back of the engine, its about a few cm's away...wtf?
The difference between stick and auto is like night and day in an E30!
89 325i sold
92 325i S52 OBD1 RIP
88 190e 5speed RIP
95 e320 SE RIP
93 190e Sold
08 c350 Summer
01 C230 Supercharged Sold
03 320i Wifes Car now
93 325is Project Build
03 GSXR 600 RIP
04 CBR 600RR Sold
06 YZF R6 Raven
Originally Posted by Axxe
I'm more interested in sticking my banana into the girl on your hood.
Stuttgart is offline   Reply With Quote
Old 04-03-2006, 09:37 PM   #2
Quack
Wheelman
Quack's Avatar
did you check if the torque converter is properly seated in your tranny, that is most likely your problem
Old 04-04-2006, 12:32 AM   #3
superman123
slushbox champion
he wouldnt have a torque converter ..he doesnt have a automatic
is that the 325 tranny on the m3 motor ?
superman123 is offline   Reply With Quote
Old 04-04-2006, 12:53 AM   #4
Ital_325i
Lost in a world of Chaos
Ital_325i's Avatar
The motor and tranny need to be lined up 100% true. If not, your gonna struggle for a while. Try wiggling it back and fourth, as well as up and down, until they line up. After that, it should slip in nicely.
Ital_325i is offline   Reply With Quote
Old 04-04-2006, 01:08 AM   #5
Furious
BMW again.
Furious's Avatar
did you remember that metal plate (forget the actual name) its suppose to be on and has to be on perfect.
Old 04-04-2006, 01:30 AM   #6
Soldo
Soldo's Avatar
hahahaha, i don't mean to laugh, but i remember the frustraion i went through with the same problem!
First off, did you use a clutch alignment tool to line everything up? If not, use that first, that'll line up everything in the tranny. If its only a few cm away then (like mentioned above) you just have to wiggle it around till it lines up. This is a PAIN IN THE ASSS!!
Keven Soldo
Old 04-04-2006, 01:37 AM   #7
superman123
slushbox champion
could be the release bearing ?
Old 04-04-2006, 11:20 AM   #8
ScotcH
Nope ... as stated above, it's a clutch alignment issue. The clutch MUST be centered perfectly, or it won't go. The friction on the clutch from the pressure plate will NOT allow it to move at all, so if you're out by more than even a hair, you're going to have to loosen the PP bolts, and try aligning it again. Did you try mating it with the PP just lightly tightend first, as I suggested in the other post?
Also, there is a dowel near the starter ... make sure this lines up correctly with the hole in the block or tranny (depending where you put the dowel) Might want to polish that dowel a bit as well since it can get a bit dirty and won't go in nicely.
Old 04-04-2006, 12:35 PM   #9
KIRASIR
Your Nightmare
KIRASIR's Avatar
And to add to ScotcH, since the clutch is not properly aligned, the transmission input shaft cannot engage the pilot bearring. Hence, the 2-3cm gap you are seeing. Get a clutch alignment tool from Canadian Tire.
SL
Old 04-04-2006, 06:46 PM   #10
Stuttgart
Stuttgart's Avatar
Thanx for all the help guys, went back into the garage after having a shake, and took out the slave cylinder got a tie to hold the everything inside back, (big bar thing behind the bearing) don't know the proper term for it, then used the clutch alignment tool to check the disc inside, everything was lined up, and then round two started, I must of wiggled it for about 10min straight, then as I gave up it slide in soooooooooooo easily without much force (at this point I had none left n e ways) all in all for anybody tryin to learn from all the good advice and my experience from all this - make sure ur ****in shit is lined up! and ur bearing and (big bar/plate wtf is that thing called???LOL) is all the way back. I want to thank everybody again for all ur help, I am currently now struggling with bypassing the steering column as I am tryin to get the motor and tranny back in :-(
89 325i sold
88 190e 5speed RIP
95 e320 SE RIP
93 190e Sold
08 c350 Summer
03 GSXR 600 RIP
04 CBR 600RR Sold
06 YZF R6 Raven
Old 04-04-2006, 06:48 PM   #11
Stuttgart
Stuttgart's Avatar
P.S. Does anyone know someone who has a 93-95 obd1 vanos ecu and harness? It's the only thin I now need to complete the m3 obd1 conversion, Thanks for any help/direction!
89 325i sold
88 190e 5speed RIP
95 e320 SE RIP
93 190e Sold
08 c350 Summer
03 GSXR 600 RIP
04 CBR 600RR Sold
06 YZF R6 Raven
