Old 04-03-2006, 11:07 AM   #1
BennyL
7th Gear Member
BennyL's Avatar
how to set the time on OBC?
hey guys, how do you get into the time set interface on a 7-button OBC?
i need to change over for daylight savings, and i can't remember how. dont have the owner's manual either.
thanks!
Old 04-03-2006, 11:32 AM   #2
rico328i
time set
Hold 'TIME' button for a second or 2. Should flash and commence set mode. Then use the left mos buttons (1, 10, 100, 1000) to set proper time. Finish off by hitting 'Time' again. Done.
Just did this myself yesterday so it's fresh in my head.
Old 04-03-2006, 01:28 PM   #3
uber e36
uber e36's Avatar
This is one of the things girlfriends are good for!
Daily: '06 S4
Wife: '05 X5 4.4i
Fun: '95 325is
Old 04-03-2006, 04:27 PM   #4
Justin e36
Justin e36's Avatar
That's for an 11 button. Though I think the 11 button only has a "CLOCK" and "DATE" button... thinking from memory here, since I only have a 7 button in my car.
1. For a 7 button, hold down the HR/DAT button for 3 seconds. The time will begin flashing.
2. Now use the h/DAT and min/DAT buttons to adjust the minutes and hours on the display.
3. You can also press the °C/°F button at this time to change between 24-hour display, and 12 hour (AM/PM) display. (this is an undocumented feature.)
4. Press SET to save the time.
5. Now you can input the date using the same h/DAT and min/DAT buttons. Press SET again, then you can input the year, and finally press SET one last time.
Old 04-03-2006, 05:08 PM   #5
BMWFORLIFE
Technoviolet Shifting
^^^^^ being a 318 owner with a 7 obc that is correcy
BEEEEEEEE EMMMMMMMM DOUBLEUUUU
BMWFORLIFE is offline   Reply With Quote
Old 04-04-2006, 12:35 AM   #6
BennyL
7th Gear Member
BennyL's Avatar
thanks justin (and anthony)
it was driving me nutz for the last few days. but i got it set now.
although, it never went to the date set interface. i just held the HR/DAT button until the colon in between the hour and minutes started flashing (not the numbers themselves) and then used the h/DAT and min/DAT buttons to adjust the minutes and hours. then i pressed the SET button, and that was it!
