Old 03-30-2006, 12:17 AM   #1
Mr seville
Mr seville's Avatar
FS: Zex nitrous system
hey guys i have a complete nitrous set i want to get rid of. i can even get it installed for you for only $150 more(usually over $600 for install). lines run but never used, tank was never filled or even put in the car he just got the shop to install it cause they did it free. ready to deliver tommorow. you'll find a picture below of everything it comes with. GTA only guys and i will take a roadtrip to quebec buffalo for pick up. only purchased in december. it also comes with the optional pressure gauge that originally cost $100 U.S.
PRICE:900 o.b.o. normally over 1200 in stores plus install. (price on zex website is U.S. minus shipping and duty)
post here or pm me for total privacy
here are the specs:
4 & 6 Cylinder Nitrous System
Part #82021
A complete "Wet" nitrous system. Everything is included for a safe, proper installation.
Designed to work safely on stock type engines, but is also engineered to perform flawlessly on highly modified turbocharged and supercharged combinations. The ideal nitrous system for any fuel injected vehicle.
• All major components are factory pre-assembled inside the "Nitrous Management Unit". Easy, plug and play, two-hour installation.
• ZEX Nitrous Systems have an advanced, patented feature called "Active Fuel Control". This feature monitors nitrous bottle pressure and adds or subtracts enrichment fuel so the engine never runs too rich, or too lean, when you engage the nitrous system.
• ZEX "Wet" nitrous systems activate at wide-open throttle using advanced electronics that monitor your engine's throttle position sensor. This makes using your nitrous system very easy and reliable.
Mr seville is offline   Reply With Quote
Old 03-30-2006, 05:18 AM   #2
Hound
V-Dub in da House
Hound's Avatar
Send a message via MSN to Hound
good luck with the sale mario bump for a great guy
Sean
07 GTI, Revo Stage II, 3" catless GHL exhaust, OEM R32 rear conversion, 17x9 + 17x11 215/45/17 all around on genuine BBS RS's, B&G RSII coilovers
96 Harliquin Golf
Hound is offline   Reply With Quote
Old 04-03-2006, 08:32 PM   #3
Mr seville
Mr seville's Avatar
bump for the cheese and crackers that are infront of me
