Old 03-28-2006, 08:00 PM   #1
Kris77
My ABS light is always on
My ABS light is always on and i am wondering if i can turnt the light off from the dash board. I don`t want to fix the ABS.How can I fix this problem?
Kris77 is offline   Reply With Quote
Old 03-28-2006, 09:04 PM   #2
Justin e36
Justin e36's Avatar
If you don't want to fix the ABS, then take the ABS bulb out of the dashboard. Note that if you have traction control on your vehicle, that will also not be operating.
Old 03-28-2006, 10:19 PM   #3
MOTRONIX
MOTRONIX's Avatar
kris, what kinda car do you have?
common issues i have seen on:
e30--- the voltage protection relay under the driver side kickpanel just above the abs control unit. its a small silver relay... if the car was boosted, chances are that protection relay will get blown... you can take them apart and fix the cold solder points. or a new sensor is 65.00 and it plugs in.
e36--- typically the front abs sensors go open and cause the light to come on. i change them in pairs if one has gone bad. each sensor i belive is 148.00 each
i hope this helps.
dave
MOTRONIX is offline   Reply With Quote
Old 03-29-2006, 12:07 AM   #4
Justin e36
Justin e36's Avatar
i hope this helps.
dave
any other ideas? my wheel sensors are fine, ABS computer has been changed. I'm thinking the ABS pump? ... my ABS light used to be intermittent, and sometimes when the ABS would kick in THEN the light would come on.. now it's on all the time. ideas?
Old 03-29-2006, 12:38 AM   #5
bimmer318ti
bimmer318ti's Avatar
Send a message via MSN to bimmer318ti
Justin - I have the same problem. I took it to charlie (thinking its sensors) and he said my rotors are almost dead hence the problem. (I just got my pads changed and still the problem persists). Sometimes for me the light does not come on for sevral hours and suddenly it turns on. However latley the light has been on continuously and I believe the ABS is not working.
Visit " My Square One Condo " for all your Mississauga condo news
bimmer318ti is offline   Reply With Quote
Old 03-29-2006, 04:28 AM   #6
Justin e36
Justin e36's Avatar
there is a metal part behind the rotor that works with the wheel sensors. I think this is what he meant, not rotors. When your ABS light is on, your ABS is not working.
The thing is.. is your ABS light on as soon as your start the car, or only when you start driving?
Old 03-30-2006, 11:05 AM   #7
bimmer318ti
Sometimes its on when I turn on my car, but most of the time it turns on after the first time I apply the break pedal.
Old 03-31-2006, 04:27 PM   #8
Calvé
Benfiquista
Calvé's Avatar
Yeah, mine came on today too and hasen't gone away yet...
Calvé is offline   Reply With Quote
Old 03-31-2006, 05:50 PM   #9
Kris77
as soon as i start the car the light gose on. I drive a 96 BMW 318is coupe.
Old 04-03-2006, 02:17 PM   #10
Calvé
Benfiquista
Calvé's Avatar
I've noticed that mine only comes on if I start the car with my brake pushed all the way to the metal... If I start my car with the parking brake or without slamming down the brake peddle it's fine... and my brakes work great too!
Old 04-03-2006, 02:56 PM   #11
Furious
BMW again.
Furious's Avatar
ive had an issue with my left front speed sensor for like 2 years now, just too lazy and cheap to fix it. the speed sensor is usually the main culprit to cause the ABS light to go on. but the speed sensor itself is pretty pricey.
Old 04-03-2006, 04:48 PM   #12
bimmer318ti
bmw's in gerneral have a lot of problems with sensors - they keep going out and they are $$$ to fix.
