Old 03-23-2006, 11:20 PM   #1
keven
keven's Avatar
random beeping!!
well i dont know if this is me just going crazy but ill be driving and i will here to random beeps out of no where but no CEL light comes on or anything and its not my dorr i know that much. I apreciate any input
keven is offline   Reply With Quote
Old 03-23-2006, 11:36 PM   #2
moto-menace
moto-menace's Avatar
how often is it?
i know if u hit that memo button or somthin it will beep every hour, or however long u set it 2 beep..mine beeps 1 minute before each hour.
also beeps when the temperature changes and stuff..maybe that?
[IMG]
moto-menace is offline   Reply With Quote
Old 03-24-2006, 01:25 AM   #3
JNSchnitzer
Christ is King
JNSchnitzer's Avatar
yep mine beeps 1 minute after each hour
JNSchnitzer is offline   Reply With Quote
Old 03-24-2006, 01:30 AM   #4
fletch
M50B20 Engine
Send a message via MSN to fletch
mine when the temperature hits +3c will beeps how can i reset this or cancel it?
Originally Posted by kawasaki kid
how often is it?
fletch is offline   Reply With Quote
Old 03-24-2006, 02:45 AM   #5
Justin e36
Justin e36's Avatar
the chime (gong) will come on when:
- temperature DROPS to 3 degrees celcius, or when starting the car and it is already 3 or colder out. This is a notification to let you know to beware of possible black ice on the road. Additionally, this is when your heated mirrors and heated windshield washer nozzles are turned on. The temperature display on your OBC will blink as well.
- when you press the MEMO button on your OBC. A small graphic will appear on your On Board Computer that looks like ·∙| ... this will chime one minute before every hour to remind you in case you have a favorite track on the radio you'd like to tune in to.
- When the CHECK control feature on your 11+ button OBC recognizes a fault, to get your attention to the OBC.
It can not be disabled without disconnecting the gong under your dashboard.
Old 03-24-2006, 05:40 AM   #6
makker
Justin, my outside temp sensor is a bit messed up, and currently reads -35 all the time. Does that mean my mirror heater, etc will be active for the entire time the car is running?
makker is offline   Reply With Quote
Old 03-24-2006, 06:25 AM   #7
Justin e36
Justin e36's Avatar
Indeed it does, it also means your car will be given much much more fuel when you're starting it up, as the computer believes it is -35 degrees outside, so the air/fuel mixture is adjusted to ensure it starts up. You probably notice when you start the car, the tachometer rises way up before it settles. Good chance that it idles high until the engine warms up fully too.
Old 03-24-2006, 01:31 PM   #8
thinair
moderationistismingly
thinair's Avatar
Not true. The air temp sensor that feeds the OBC isn't the same as the one that feeds the ECU. The OBC sensor is in the left brake duct, the ECU temp sensor is in the intake manifold. I know this because I had to relocate my intake temp sensor when I did the M50 manifold swap.
Old 03-24-2006, 01:38 PM   #9
Justin e36
Justin e36's Avatar
Maybe it's different for M42's? I disconnected my temp sensor to enable the heated mirrors when I was doing the custom wiring for them, and when starting the car, the change was obvious right away.
Old 03-24-2006, 02:22 PM   #10
bimrboy
Send a message via MSN to bimrboy
thanks for answering this questions I was wondering the same thing, my car beeps 3 times and flashes 3C when I started it up this week a couple times.
bimrboy is offline   Reply With Quote
