Old 03-17-2006, 05:54 PM   #1
carbon
carbon's Avatar
Question M3 1999 Maf
I have a MAF with 3" diameter (stock). I saw in a place a swap of the MAF 3"1/2 and the trottle body more bigger. It's is true? Good Mod? What is the model is this?
carbon is offline   Reply With Quote
Old 03-17-2006, 05:58 PM   #2
Is it from a e39 540? you sure you're not talking about the HFM?
Old 03-17-2006, 06:03 PM   #3
carbon
carbon's Avatar
No, on the Air Flow Meter (MAF)
Old 03-17-2006, 07:42 PM   #4
JazzM
Yes, its a popular swap. You have 3 options in terms of the MAF:
- Euro M3 (3.5 " MAF)
- e39 540 MAF (same as above)
- Dinan (same as above but more $$)
You can get your TB bored out as well... it will improve your throttle response. Contact Randy (Empowered) on this board as he can do this for you. He'll be doing 6 for me soon Dinan also has a bored out TB on an exchange basis but its more expensive plus Randy can go bigger
However, before you do this, I would strongly suggest that you do Schrick cams first then after thats done an M50 manifold with 24lbs injectors, the MAF/TB and software. If you do it in that order you'll have the biggest gain per $ spent.
T.
T.
