Old 03-16-2006, 11:22 AM   #1
Shark
Shark's Avatar
19" rims
I want to put on some 18"s rims for my Z3 2.8L but I found a good deal on 19"s. I know that 19"s will have a harsh ride to them, which it's ok with me. Just wondering, will there be any rubbing on stock springs? I see that on tirerack.com, it can be done. And I will eventually put on new springs on it too, thinking of putting on H&R. Just wondering what you guys think?
Shark is offline   Reply With Quote
Old 03-16-2006, 11:41 AM   #2
BMWF1
Guest
Posts: n/a
if you put 19's on yes it will be a very stiff ride .... However you should not have any rubbing with the stock setup. the wheel wells are very big, and on 2000-2002 they are even bigger. However I do recommend you drop it as it will sit pretty high on 18's.
If you put on just springs on your Z your shocks will last you no more then a year, its recommend you change both at the same time, but if it's low miles and you wanna get the most out of your current shocks then just ridem out and make sure to have a set of bilistens laying around ...
19s is the absolute biggest you should go and if you drop the car it will fill in the entire wheel well. If you want some more information check out the Z3 section at bimmerforums.com, They have some Z guru's on there.
Anyway good luck and make sure to post pictures when your done with it.
**i'm riding on 18's by the way.
Old 03-21-2006, 11:23 PM   #3
Shark
Shark's Avatar
I'll keep you posted
Old 03-24-2006, 03:10 PM   #4
330ci05
330ci05's Avatar
i changed my springs to H&R and i have 19k+ on the shox,struts and there is no wear to them at all, still feels like day one
330ci05 is offline   Reply With Quote
Old 03-24-2006, 08:34 PM   #5
BMWF1
Guest
Posts: n/a
Zee's are alot different with suspension, trust me on this one.
Old 03-24-2006, 08:45 PM   #6
Soldo
Soldo's Avatar
Ya, the Rears are similar to the E30/Ti's and the fact that its a convertible makes it VERY harsh on suspension components!
Keven Soldo
Old 04-01-2006, 03:52 PM   #7
330ci05
330ci05's Avatar
yeah guess
Old 04-04-2006, 02:45 AM   #8
Shark
Shark's Avatar
what do you guys think on a red Z3, 19" chrome rims?
Old 04-04-2006, 10:46 AM   #9
JazzM
Don't get 19's. I used to have them. Its a very harsh ride and you will bend them very easily. Trust me on this one. Get a nice set of 18s instead
T.
T.
Old 04-04-2006, 06:45 PM   #10
Shark
Shark's Avatar
what chrome rims? or
Old 04-08-2006, 01:16 PM   #11
BMWF1
Guest
Posts: n/a
pass on the chrome.....pewter or gunmetal coded are nice
