Old 03-15-2006, 01:38 AM   #1
OBC bitching
Ok check tail light, and more recently, brake light failure.
all the lights work. everything's stock. what's the deal
Old 03-15-2006, 02:04 AM   #2
Alizay
Bad Man Wagon
shit... i have the same problem... i'm gonna have to get it checked out by an electrician.
---My Ride---
2003 BMW 330i M-Package (E46)
LOOKING FOR:
Smoked Tail Lights, Corners and Side Markers for my 2003 BMW 330i
BMW = Bad Man Wagon!!!
Alizay is offline   Reply With Quote
Old 03-15-2006, 02:07 AM   #3
djcontra
Gets Blown Daily
djcontra's Avatar
how do all the wires/connectors look? Are they all snug, and secure? Maybe try to take all of the bulbs out and check for corrosion and clean it off...
Mods
-Shortstack headers
-Vortech RRFPR
-255LPH Walbro fuel pump
-Keskin KT1 17x8.5 & 17x10
-Remus full catback
-SMT6 EMS (Untuned)
Old 03-15-2006, 02:55 AM   #4
Stuttgart
Bmw = Bought My Wife
Stuttgart's Avatar
Send a message via MSN to Stuttgart
Common problem with 3er's don't know what the remedy for this one is. Mine does the exact same thing when they work or don't work. Your definetly not alone.
The difference between stick and auto is like night and day in an E30!
89 325i sold
92 325i S52 OBD1 RIP
88 190e 5speed RIP
95 e320 SE RIP
93 190e Sold
08 c350 Summer
01 C230 Supercharged Sold
03 320i Wifes Car now
93 325is Project Build
03 GSXR 600 RIP
04 CBR 600RR Sold
06 YZF R6 Raven
Originally Posted by Axxe
I'm more interested in sticking my banana into the girl on your hood.
Stuttgart is offline   Reply With Quote
Old 03-15-2006, 03:00 AM   #5
Furious
BMW again.
Furious's Avatar
your bulbs are stock as well? i find that even nonstock bulbs can cause it, as well as bad contact or contacts, corrosion and loose connections as contra said.
Old 03-15-2006, 05:45 AM   #6
Stuttgart
Stuttgart's Avatar
sand them with some 220 grit, will clean that @#$( up good.
89 325i sold
88 190e 5speed RIP
95 e320 SE RIP
93 190e Sold
08 c350 Summer
03 GSXR 600 RIP
04 CBR 600RR Sold
06 YZF R6 Raven
Old 03-15-2006, 09:31 AM   #7
Andy E34
Registered User
Andy E34's Avatar
Send a message via MSN to Andy E34
Yep mine too....
read another post somewhere that ECU looks at resistance of the circuit so cleaning the contacts and possibly just replacing the lamps in the problem circuits fixes the problem? Sandpaper/ contact cleaner etc. would be my vote for the 1st thing to try.
My SRS dash light stays on and I hear that can be fixed with a re-set tool? Anyone have one of these $120 "tools"
Andy E34 is offline   Reply With Quote
Old 03-15-2006, 11:48 AM   #8
vadim321go
vadim321go's Avatar
mine as well, i actually checked out the wiring in the trunk and i found out they areny plugged in to the original place they shud be, they are rewired! however they do work no problem. check out wats going on in ur trunk
Proud owner of a 95 325i
Old 03-15-2006, 11:50 AM   #9
Soldo
Soldo's Avatar
I have the exact same problem.... and i fixed it by accident.
The solution was.... OEM clear tails!
Once i put the OEM clear tails, i noticed that there was an extra pin in the lights... and i guess the conncetion was better also
Keven Soldo
Old 03-15-2006, 03:28 PM   #10
rico.r on the boards has the tool you're talking about andy
yeah i may sand em down. today turned the car on, no errors. stupid OBC
Old 03-15-2006, 03:37 PM   #11
Furious
BMW again.
Furious's Avatar
Originally Posted by Andy E34
Yep mine too....
srs? thats airbag right? i forget... in any case if it is, a reset tool will only clear the fault for the moment, if you do have a true problem with the SRS than it will come back. probably one of two major causes.. the passenger sensor (under the passenger seat) or one of the seatbelt sensors.
Old 03-15-2006, 04:21 PM   #12
Andy E34
Registered User
Andy E34's Avatar
my '93 has no passenger side air bag...so must be issue with drivers side? How do I check for the problem...can this be diagnosed by another fault "tool" and then ??
BTW...SRS = supplemental restraint system... I think....yep the air bag...LOL
Old 03-15-2006, 04:36 PM   #13
Furious
BMW again.
Furious's Avatar
even though you may not have a passenger side airbag, the sensor for the pass seat is still there. im still guessing its either that or the seatbelt buckle. to find the problem? well you need to pull the fault code and referance it. using a modec will find your problem, however im not sure if aftermarket code readers give that information.
Old 03-15-2006, 06:04 PM   #14
BennyL
7th Gear Member
BennyL's Avatar
i know the solution!
pull out your OBC and trade me for my 7-button OBC! no warning lights to deal with
Old 03-16-2006, 12:25 AM   #15
app
The worst is the brake circuit failure. It constantly flashes. Only happens in humidity too.
Luke
92' 325i
app is offline   Reply With Quote
