Old 03-14-2006, 11:32 PM   #1
Stuttgart
Bmw = Bought My Wife
Stuttgart's Avatar
Send a message via MSN to Stuttgart
is it possible to hook up a 318i manual tranny to a 3.2l m3 engine?
the reason im askin is I just got a tranny installed, i paid for a 325i manual. I drove the car with the 325i motor hooked up to it and its perfect but i just got a hunch that its not a 325i because the reciept says 318 but i told them i need a 325i. The shift points are the same. 3rd gear is like b4 tops out at 145kmh just like it did with the 325i tranny. How can i tell if its a 325i tranny and not a 318i tranny. I took out my engine b.c. i want more power, got a m3 engine ready to install. HELP GUYS!
The difference between stick and auto is like night and day in an E30!
Originally Posted by Axxe
I'm more interested in sticking my banana into the girl on your hood.
Stuttgart is offline   Reply With Quote
Old 03-15-2006, 12:09 AM   #2
BennyL
7th Gear Member
BennyL's Avatar
i don't know, but i assume there should be some sort of serial # on the transmission to identify it by...
Old 03-15-2006, 12:24 AM   #3
KIRASIR
Your Nightmare
KIRASIR's Avatar
E36 318 tranny = E36 325 tranny. They are identical.
It will also work fine with an M3 engine.
Old 03-15-2006, 12:37 AM   #4
superman123
slushbox champion
won't fit on a m3 motor u would need a 328 tranny
superman123 is offline   Reply With Quote
Old 03-15-2006, 12:38 AM   #5
uber e36
uber e36's Avatar
I personally think you should get the M3 tranny which is rated to handle more torque... I drive a 325 and am replacing my tranny this spring. I'm going to drop in an M3 tranny as I plan to make more power in the next year or two...
Daily: '06 S4
Wife: '05 X5 4.4i
Fun: '95 325is
uber e36 is online now   Reply With Quote
Old 03-15-2006, 12:52 AM   #6
KIRASIR
Your Nightmare
KIRASIR's Avatar
Please do not post if you have not idea what you are talking about. 318/325 fits just fine with the M3 motor and can handle the power/torque.
Neither Getrag nor ZF tranny will last long if the car is "drag raced" from every stop light.
Old 03-15-2006, 01:14 AM   #7
Stuttgart
Stuttgart's Avatar
KIRASIR, ty and geoff it would probably best i did, but i got to wait till this one dies. KIRASIR, THANKS SO MUCH FOR RELIEVING MY WORRIES! I drag raced the old tranny everyday basically and thats how my 2nd gear went! I read somewhere that the Toyota Supra's have the Getrag as well, is this true?
Old 03-15-2006, 08:47 AM   #8
M3ti Compact
Fuel Efficient 318 Member
M3ti Compact's Avatar
Yeah, Toyota uses a Getrag...but I dunno if it's the same one in the BMW's...
Old 03-15-2006, 08:51 AM   #9
ZiMMie
Send a message via ICQ to ZiMMie Send a message via MSN to ZiMMie
depends on wat yr 318 the tranny its coming from.
Old 03-15-2006, 09:09 AM   #10
uber e36
uber e36's Avatar
Perhaps this answer will be a little more educated for you:
318 - Getrag S5D 200G (92-95)
318 - Getrag S5D 250G (96-98)
323/5 - Getrag S5D 250G
328 - ZF S5D 320Z
M3 - ZF S5D 310Z (95)
M3 - ZF S5D 320Z
*I was told that the 200/250/310/320 #s were how much torque it can handle
The BMW Service Manual States:
"Due to different power characteristics and performance requirements, four different manual transmissions are used..."
KIRASIR - Do you have some information that the engineers in Munich don't have?
Stuttgart - I'd play it on the safe side...
Daily: '06 S4
Wife: '05 X5 4.4i
Fun: '95 325is
Old 03-15-2006, 12:36 PM   #11
KIRASIR
Your Nightmare
KIRASIR's Avatar
geoff@bmw,
All of the transmissions you listed are all PHYSICALLY interchangeable between the different e36 models providing one uses appropriate clutch fork, linkage, driveshaft and a couple of other parts.
With regards to the extra power and torque.
All of the Getrag transmissions are perfectly capable of holding up to 200+hp providing the owner does beat the shit out of them. Even ZF synchros will not withstand much abuse if the car is drag raced from every stop lights.
There are dozens of 318ti's with DASC/turbo/6-cyl swaps pushing 200+hp and still use the stock Getrag transmission. A number of these cars are heavily tracked as well (ask around the 318ti list). To date, I haven't heard a single complaint with regards to the transmission from any of them myself included, and I’ve been a member of that list for 6 years.
Furthermore, the parts that most likely WILL go first will be not the transmission but the differential and the clutch.
Moreover, a ZF transmission will add at least $1000+, plus the driveshaft, plus the linkage parts to the cost of the swap. If Stuttgart can spend such money on the ZF transmission then by all means he should get one. However, in my opinion this money can be better spent somewhere else. (///M diff for example)
Most of the problems with manual BMW transmissions have little to do with extra torque and power but with how they are used. Changing gears quickly, without fully disengaging the clutch, and without matching the revs is a sure way to toast ANY transmission (synchos and forks are pretty delicate parts).
Cheers,
SL
PS Stuttgart, no clue about the Supras
328 - ZF S5D 320Z
M3 - ZF S5D 320Z
Old 03-15-2006, 12:41 PM   #12
jeffrie
Addict
jeffrie's Avatar
E30, E36, & E46 tranny's are all physicaly interchangable with the above mentioned differences.
Old 03-15-2006, 01:17 PM   #13
uber e36
uber e36's Avatar
KIRASIR - my apologies, I your post was right after mine...
I guess I just like to go overkill on everything, so I'd rather be safe the first time.
Daily: '06 S4
Wife: '05 X5 4.4i
Fun: '95 325is
Old 03-15-2006, 02:48 PM   #14
Stuttgart
Stuttgart's Avatar
thanx for all the info kirasir, gives me more peace of mind now. I will look into the supra thing...
Old 03-15-2006, 05:53 PM   #15
thinair
moderationistismingly
thinair's Avatar
Send a message via ICQ to thinair Send a message via MSN to thinair
The Supra TT uses the same 6spd Getrag that the E46 M3 uses.
