Old 03-14-2006, 08:30 PM   #1
Justin e36
Justin e36's Avatar
how much gear oil...
is needed for our e36 5-speed tranny, and 318 diff...?
Old 03-14-2006, 08:44 PM   #2
MOTRONIX
MOTRONIX's Avatar
get yourself 4 ltrs of gear oil. its usually 2 for the diff and 1.5ish for the rear diff.
dave
MOTRONIX is offline   Reply With Quote
Old 03-14-2006, 09:31 PM   #3
ZiMMie
Justin remember ur Manual Tranny Takes ATF fluid. DEXTRON II. they should be a tag on the tranny tell u wat type of fluid to put in.
1.2L ATF Dextron II
1.8L (API - GL5 SAE 90 Gear Oil)
Old 03-14-2006, 09:41 PM   #4
Furious
BMW again.
Furious's Avatar
this is a stupid question, but you remember how to change right justin?
Old 03-14-2006, 10:33 PM   #5
Justin e36
Justin e36's Avatar
nope, have never changed it before... figure it's about time I do so.
Old 03-14-2006, 11:05 PM   #6
Furious
BMW again.
Furious's Avatar
if you do it this weekend gimme a holler, ill help you out.
Old 03-14-2006, 11:14 PM   #7
BennyL
7th Gear Member
BennyL's Avatar
dont the transmissions use dexron III, not II?
Old 03-15-2006, 07:26 AM   #8
jeffrie
Addict
jeffrie's Avatar
Havn't ever filled my tranny on a e36, if like a e30 pretty simple, Theirs a second bolt to remove @ the fill line, once leaking out on a level seface it's full (ATF). 17mm hex nut I beleive.
As for the diff 1L of normal type 80/90 gear oil, the smelly stuff.
Bently says 1.1L
I only put in a litre of synthetic 75/90 while I had it on the bench.
Need about 2L (spilage, pump line priming) to gravity feed it with diff on the car, bit of a PITA on a 318 to get the 14mm hex in, the spare tire well is too close to use a ratchet.
