Old 03-12-2006, 11:31 PM   #1
Stuttgart
Bmw = Bought My Wife
Stuttgart's Avatar
Send a message via MSN to Stuttgart
Engine removal. Calling all mechanics.
I am removing my engine in preparation for an engine swap and I am stuck. Do I remove the tranny torx-hex bolts that connect the tranny to the engine or do I remove the bolts connecting the tranny to the driveshaft?
Basically, is it better to remove the tranny before the engine is removed or after?
The difference between stick and auto is like night and day in an E30!
89 325i sold
92 325i S52 OBD1 RIP
88 190e 5speed RIP
95 e320 SE RIP
93 190e Sold
08 c350 Summer
01 C230 Supercharged Sold
03 320i Wifes Car now
93 325is Project Build
03 GSXR 600 RIP
04 CBR 600RR Sold
06 YZF R6 Raven
Originally Posted by Axxe
I'm more interested in sticking my banana into the girl on your hood.
Stuttgart is offline   Reply With Quote
Old 03-12-2006, 11:40 PM   #2
e30_kid89
The Afro-stig
e30_kid89's Avatar
im not a mechanic but ive been through the bentley u have to disconnet the tranny from the driveshaft then the tranny from the engine the engine comes last of of those 3
hope that helps
Old 03-12-2006, 11:45 PM   #3
ZiMMie
if u are removin it with the tranny then leave the TORX bolts alone and disconnect the driveshaft. but if u lke to separete the tranny from the engine then unbolt those torx screws and pry between the engine/tranny to get them seperated.
#E36-S54 #CSLWannabe
Old 03-12-2006, 11:47 PM   #4
Stuttgart
Stuttgart's Avatar
thanx guys, but can't i just disconnect the driveshaft from the tranny and disconnect the tranny once I take out the engine. Wich is easier?
89 325i sold
88 190e 5speed RIP
95 e320 SE RIP
93 190e Sold
08 c350 Summer
03 GSXR 600 RIP
04 CBR 600RR Sold
06 YZF R6 Raven
Old 03-13-2006, 12:08 AM   #5
Justin e36
Justin e36's Avatar
you got it right.
it is much easier to pull out the engine + tranny as once piece, same when dropping in the new engine. bolt on the transmission first, and drop it in together.
Old 03-13-2006, 12:24 PM   #6
ScotcH
Yup, if you can get it out in one piece, that is definitly easier. I just took out my tranny yesterday to install a LW flywheel and race clutch, and it was a pita to get at all the torx bolts ... took about 4hrs to get it out (boy I sure wish I had a lift!)
To make your like even easier, remove the whole front end clip (bumper, rad, nose piece, etc.) It only takes about 1 hr to do, and will save you the hassle of trying to tilt the engine up out of the bay.
Old 03-13-2006, 01:01 PM   #7
Bruno
Bruno's Avatar
Once you know where all the bolts are, it isn't hard to pull a tranny out. I installed my new race clutch and tranny with new driveshaft and linkage this week end, it was pretty easy.
Impact tools and super long extension helps a lot.
I would pull the tranny then remove the hood and pull the engine up.
I pulled engine and tranny together when I send my engine to be rebuilt and it was a bit of a pain not to damage anything in the way.
If you have the front end parts removed, sure do it that way, else pull the tranny out then the engine. Either way works. I pulled my tranny out so many times that it is probably easier for me to pull the tranny out 1st.
Once the car is on jack stands, there is plenty of room to acess all the tranny bolts. Only the starter bolts are a pain to install on some cars.
Don't forget that there is a bolt on the passenger side at the back of the tranny holding a shield. (10mm wrench). If you are removing the tranny.
'76 2002
'85 Euro 635csi M30 Turbo race car
'04 330i SSG
'05 530i
Bruno is offline   Reply With Quote
Old 03-13-2006, 05:45 PM   #8
ScotcH
Originally Posted by Bruno
Lol ... I'm using the exact hoist right now to hold the engine up while I remove the oil pan (to weld the pump nut!). Out of curiosity, what did you use for the rear chain attachment? There does not seem to be anything there, so I had to jimmy up a rig
You still have shields? ... this is a race car, right?
(good tip for the street cars though)
Old 03-13-2006, 05:53 PM   #9
Bruno
Bruno's Avatar
I never really paid attention to the shield between the transmission and the engine, I though it had a purpose somehow.
To lift the engine, I used the engine block opening at the back of the engine (like a big hole on the driver side design to lift the engine) and for the front, I used the BMW special hook that is in the engine also. I didn't have to make anything each time I had to lift a bmw engine.
The hoist was cheap so I bought it along with an engine stand. Very handy.
'76 2002
'04 330i SSG
'05 530i
Old 03-13-2006, 08:22 PM   #10
Stuttgart
Stuttgart's Avatar
thanx for all the help guys.
89 325i sold
88 190e 5speed RIP
95 e320 SE RIP
93 190e Sold
08 c350 Summer
03 GSXR 600 RIP
04 CBR 600RR Sold
06 YZF R6 Raven
Old 03-13-2006, 08:30 PM   #11
e30_kid89
The Afro-stig
e30_kid89's Avatar
how much for the hoist and the stand?
Old 03-15-2006, 03:45 AM   #12
Stuttgart
Stuttgart's Avatar
dunno how much it is to buy, its around $50 CAD to rent per day. (the hoist that is)
89 325i sold
88 190e 5speed RIP
95 e320 SE RIP
93 190e Sold
08 c350 Summer
03 GSXR 600 RIP
04 CBR 600RR Sold
06 YZF R6 Raven
