Old 03-12-2006, 06:51 PM   #1
vadim321go
vadim321go's Avatar
tire pressure
alrite i was looking at my door to find out the proper pressure and got tottaly confused, there were numbers and squares and triangles and i was
what is the proper pressure for a 95 325i? my old car was 30psi
Proud owner of a 95 325i
Old 03-12-2006, 08:00 PM   #2
fletch
M50B20 Engine
Send a message via MSN to fletch
If 2 people in front 3 in rear --> (front tire)29psi/(rear tire)32psi
but my car only me and my gf so i use 29psi/29psi
fletch is offline   Reply With Quote
Old 03-12-2006, 08:50 PM   #3
Justin e36
Justin e36's Avatar
out of the factory tire pressures for the 325i are:
front: 29 psi
rear: 32 psi
(as fletch said already.)
with 5 passengers + luggage, the specs (factory) are:
front: 32psi
rear: 39psi
if you are using the trailor hitch then increase the rear tires by 3psi.
note that changing your suspension, tire size, and vehicle weight can all affect the recommended PSI.
Also note that (bmw?) PSI numbers are given and recommended at 10 degree (celcius) weather (18`F). Tire PSI can fluctuate by +/- 4 PSI in extreme cold, or warm, temperatures. So adjust your PSI accordingly depending on the current weather conditions.
Old 03-12-2006, 11:02 PM   #4
vadim321go
vadim321go's Avatar
well considering temperatrues are getting into the 10's im gonna go with 29/32
thx a lot guys
Old 03-13-2006, 11:03 AM   #5
spooner_dee
Has no idea whats goin on
spooner_dee's Avatar
dont the tires have the proper PSI written on them?
Old 03-13-2006, 01:55 PM   #6
BennyL
7th Gear Member
BennyL's Avatar
tires have max PSI written on them
i keep mine at 30 all around
