Old 03-09-2006, 07:30 PM   #1
BMW Guy
Clunking sound from back
I have a 93 325is. When going over bumps I get a loud clunking sound coming from the right rear of the car. Is there any common problems with shocks and/or shock bushings wearing out? Please advise. Thanks
BMW Guy is offline   Reply With Quote
Old 03-09-2006, 07:35 PM   #2
Furious
BMW again.
Furious's Avatar
yikes i kinda have the same issue, mine only makes the noise when going over speed bumps or out of driveways slow, i havent noticed the sound at higher speeds.... and thought maybe the subframe, but someone said that subframe failure also makes a nasty noise on hard acceleration (i have yet to comfirm how to diagnose a subframe failure though)... but i have to get the car back on the road and see for myself, it could very well be a problem with the rear shock mounts or trailing arm bushing.
Old 03-09-2006, 08:41 PM   #3
Big T
94 318is
upper rear shock mounts, big problems with those.
Goto the dealer and get m3 ones with z3 reinforment plates
Big T is offline   Reply With Quote
Old 03-09-2006, 08:53 PM   #4
Soldo
Soldo's Avatar
Ya, more than likely its your RSM, mine are shot to hell and make a noise like all hell breaking loose at speeds above 120km!
Keven Soldo
Old 03-09-2006, 09:33 PM   #5
markw
markw's Avatar
my car did that... it was my rear control arm bushings
markw is offline   Reply With Quote
Old 03-09-2006, 09:39 PM   #6
Justin e36
Justin e36's Avatar
what can cause it:
1. shock mounts, you'll notice it more on bumps and potholes.
2. trailing arm bushings, while going 40km/h slam on the gas... if the bushing is gone you'll usually feel the back of the car jerk to one side.
3. subframe bushings, you'll notice the knocking whenever the rear subframe is put under stress. bumps, potholes, hard braking, hard acceleration. it's usually a very quiet THUD sound.
4. could be any one of your mounts, or differential bolts.
Also be sure to make sure your spare tire is secured, as well as your car jack. I remember I once had a small bottle that fell down there and was rolling around whenever I hit the brakes... sounded a lot like a dying RSM.
I've had a thumping sound at the back of my car since I ran over a 4x4 log at 80km/h... fell off a pickup truck right in front of me, and the car was airborn. Looks like it's a torn subframe bushing... I just have to keep tightening that subframe bolt every year or so, till I can afford to get it fixed properly.
Old 03-09-2006, 10:48 PM   #7
vadim321go
vadim321go's Avatar
for me i my problem is that the metal panel that goes all the way under the car is rusty and in some places its broken due to rust. when the car is cold it causes it to shake and make horrible noises. dont jump the gun thinking something is truly broken. i checked everything out and everythign works, its just that stupid metal thing thats rusted
Proud owner of a 95 325i
Old 03-09-2006, 11:12 PM   #8
superman123
slushbox champion
if u hear that noise from the front ..with new struts
might that be bushings or mounts (didnt change the mounts when i changed the struts )(i kinda suspect those)
i hear it when i take a quick corner or some bumps
superman123 is offline   Reply With Quote
Old 03-09-2006, 11:47 PM   #9
Jari
Jari's Avatar
I'm betting rear shock mounts. Not an expensive fix even if you upgrade them with aftermarket mounts. I've changed mine so many times I can do them both in under an hour.
Jari is offline   Reply With Quote
Old 03-10-2006, 12:18 AM   #10
kòózy
6th Gear Newbie
I had a very similiar sounding problem with my car, and thought it was something to do with my shocks as well.
Took it in to Rocco at RMP, and he diagnosed it quickly as simply a loose parking brake, so he tightened everything up, and no more clunking/rattling
- 2012 135i
- 2012 128i *retired
- 1998 318is *retired*
kòózy is offline   Reply With Quote
Old 03-10-2006, 12:50 AM   #11
98Dinan3
98Dinan3's Avatar
just did rogue rsm's and they helped to rid the car of the rear end clunk. they're nice sturdy pieces.
Old 03-10-2006, 09:24 PM   #12
BMW Guy
It was the right RSM. I replaced both while I was at it. Both changed in less then an hour. Not bad. It's a quiet ride now. Thanks for your suggestions.
