Old 03-09-2006, 02:14 PM   #1
dirtyd14
THE PERFECT E30 perfromance parts list
well, this is the perfict e30 parts list(in my own opinion). I luckly came across some extra cash and love my car way to much to sell it and get a new car, i figures for the price i would spend on a car of my choice might as well put it inot my e30 and come out with a almost new car.
Here is the list:
Full Parts List for 1987 BMW 325e, with 2.8L Turbo motor.
Intake/Exhaust/Forced Induction:
-Turbonetics T3/T4 .63 .82 stage 3 super v trim ball Bearing Turbo
-Tial 38mm external wastegate
-3" Mandrel bent custom down pipe
-3" Custom down/back pipe
-3" Manual cut-out
-3” Y-pipe to 1.5” 2 pipe downpipe-back system to magnaflow muffler.
-Turbo manifold adapter
-Turbo XS RFL BOV
-Turbo XS manual boost controller
-Custom front mounted intercooler (FMIC)
-2.5" to 3" Mandrel charge pipes
-Cone intake filter
-Innovate LM1 wideband
-Innovate LM3 data logger
-HKS type-1 turbo timer
-Multi-throttle intake system (BMP)
-Split Second Air Fuel Ratio Calibrator
-Mass air conversion (BMP)
Cylender head (top end):
-Metric blue grade 12.9 head bolts
-Port and polished cylinder head with a 3 angle grind
-Bigger Valves
-Shricks 272 Camshaft
-Performance valve springs
-7mm valve keepers (BMP)
-Adjustable Cam Sprocket (BMP)
- 2.05mm head gasket
Electrical/Fuel:
-Performance chip (Alpina B3 2.7L chip)
-Unichip piggyback
-9.3mm Plug wires
-Bosch platinum II spark plugs
-MSD Alternator
-Optima Battery
-MSD 6-BTM ignition control
-MSD Blaster2 coil
-Walboro 307 lb/hr fuel pump
-48lb injectors
-Megasquirt stand alone fuel computer
-Adjustable fuel Pressure regulator
-New fuel lines
-New high flow fuel filter
Block (bottom end):
-524td Crank shaft
- Ross Racing 85mm low compression pistons
-Forged connecting rods
-Crome-moly wrist pins
-Bore Block to 2.8L (Bore to 85mm)
-High performance piston rings.
-All new bearings/bushings/gaskets
Engine Cooling:
-Electronic Cooling Fan
-High Performance Water pump
-High Performance Radiator.
-Oil cooler
-Transmition Fluid cooler
-Differential fluid cooler
-Finned Diff cover
Drive Train:
-Z4 short shift kit
-Clutch Stop
-8lb Fly Wheel (BMP)
-Centerforce duel friction clutch
-Urethane Transmition mounts
-Urethane Motor mounts
-3.73:1 Rear Differential
Other:
-Remove P/S
-Remove A/C
-Remove belt driven cooling fan (replace with electric fan)
-Replace all hoses
-Engine cosmetics (powder coating, painting…)
Suspension/Breaks;
-H&R Cup Kit suspension (with thicker rear spring pads)
-H&R Sway Bar (front 22mm)
-H&R Sway Bar (Rear 18mm)
-Adjustable way bar links (BMP)
-Front Strut tower bar
-Rear Strut tower bar (X shaped)
-Adjustable Front camber mounts
-Adjustable Rear camber mounts
-Front & Rear Toe hook ties (BMP)
-Urethane Trailing arm bushings
-Increased Caster Bushings
-Urethane sub frame mounts
-Urethane sway bar bushings
-Front Big Break kit
-SS break lines
-All new break lines
-Cross drilled rear break disks
-Rear Break calliper rebuild
-high performance pads
-rear break bias
Exterior:
-Carbon fibre M3 front bumper
-Carbon fibre hood
-Fibreglass trunk lid
-Carbon fibre blower motor cover
-Carbon Fibre sunroof panel
-Fibreglass or carbon fibre fenders
-Light Weight Race glass
-M-tech door panels and side skirts
-AV-3 Rear bumper
-Euro Front grill
-Blacked out kidney grills
-Smoked Hella Headlights
-Smoked Fog lights
-Smoked tern signals
-Smoked Tail lights
-E30 M3 style rear spoiler (AV-3 wing)
-Rear Euro plate filler
-front Euro plate
-3M protective tape (front of car)
-Fender Flairs (BMP)
-M3 antenna
-Full role cage.
-328is badge for rear
-TURBO badge (from Porsche)
-New BMW emblems
Interior:
-Racing Seats
-Remove rear bench and carpet bench area.
-Replace floor carpeting
-Floor mats
-Racing steering wheel
-Aluminium & leather shift knob
-Aluminium e-break sleeve
-Leather e-break boot
-Vinyl cover dash and enter consol
-chrome gauge rings
-New stereo system
-BMW door jams (chrome)
-Gauges: -Voltage gauge
-Oil pressure gauge
-Air/Fuel gauge
-Fuel pressure gauge
-Nitrous pressure gauge
-Boost Gauge
-Auto meter D-PIC gauge
-Auto meter shift light
-Fire Extinguisher
-Racing harness (seat belts)
-Role cage video camera mount
-Racing pedals
Now i know this list is a little over the top, and is goin to be very expensive, i am in the prosess of getting sponsers, and like i said it will cost me the same amount as other cars i was looking at buying, such as a e46 M3, e39 M5
or the 850CSI.
and one last comment, about 1/3 of the parts listed are purchesed and ready to go. i started buy parts about 1 year ago.
dirtyd14 is offline   Reply With Quote
Old 03-09-2006, 02:35 PM   #2
static
static's Avatar
well, not to discourage you or anything (i am in process of dumping quite a bit of cash into my e30 myself) just keep in mind that if you ever were in a situation that you'd want to sell this car, you WILL loose a lot of money!
Now my biggest recommendation at this point would be for you to take the body apart as much as you can, fix all the rust, recoat with anti-rust primer, repaint. Your car is almost 20yr old it DOES have rust (unless it was in california or texas all its life)
Also consider putting in a quicker steering rack and replace all the wearable parts (esspecially all rubber parts)
One more thing: you say that you will have 3" pipe splitting into two 1.5" pipes. You do realize that the area of a 3" circle is significantly larger than the cumulative area of two 1.5" circles.
In fact let me do the math for you: A=PI*r^2 ,
so for 3": A=3.14*6^2= 113.04 sq-inch
for 1.5" : A=3.14*3^2= 28.26 sq-inch
that yields: 113.04 against 28.26*2=56.52
there you have it - you are introducing a whopping 50% of restriction right there.
Alex
Old 03-09-2006, 02:36 PM   #3
markw
markw's Avatar
And this is going to be your daily driver? Sounds like a waste of money IMO… Race glass? Carbon fiber everything?
How old are you? (just a side question…)
markw is offline   Reply With Quote
Old 03-09-2006, 02:39 PM   #4
static
static's Avatar
^^ my point exactly, unless you are made of money, i wouldn't recommend this kind of setup for DD
Alex
Old 03-09-2006, 03:02 PM   #5
I dont think he knows what he's talkin about.
He's planning on using an Alpina Performance chip, + a Unichip PiggyBack + Megasquirt stand alone.
Old 03-09-2006, 03:07 PM   #6
paul christians
87325is///MR.EVIL
^^^^that is too much going on there....WOW....
87is325///2.7L..EVIL.....
Old 03-09-2006, 03:09 PM   #7
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
Don't you know, this guy works for nasa. He has to triple up on EVERYTHING.
Old 03-09-2006, 03:18 PM   #8
paul christians
87325is///MR.EVIL
^^^e30 goes BOOOOM!!!!need another e30...just joking man, good luck on the it
Old 03-09-2006, 03:18 PM   #9
static
static's Avatar
wow! nasa employee uses e30 for daily, I am impressed
Alex
Old 03-09-2006, 03:22 PM   #10
Axxe
Axxe's Avatar
Well it makes sense, this guy is as high as a kite!! Or *gasp* a rocket!!
Old 03-09-2006, 03:26 PM   #11
paul christians
87325is///MR.EVIL
NO,it is buget cuts......hehehhe..
Old 03-09-2006, 03:26 PM   #12
330ci05
330ci05's Avatar
or the 850CSI.
leave the e30 as a winter beater and get a ///M
330ci05 is offline   Reply With Quote
Old 03-09-2006, 03:45 PM   #13
dirtyd14
im sorry i do not work for nasa, and about the alpina, unichip pigyback system, i for got to put in there that i am in the prosess of deciding on what would be the best to go with the project, i do not pain on using all 3!!!!!
I dont know what it is about the e30 but im in love with the cars. And with help from a few friends of mine who own shops and performance parts stores in the area i will be building it to be a car that i will keep for many years. The car will not be a daily driver, since all the money and sorts that i put into it, it will be stricktly for the weekends, track/strip, and show.
now like i said is it a big waist of money....ya it could be, but when will i ever have the chance to do this again in my life.
oh and for the question of my age, i am 20 years old, and i do know what im talkin about i have been doin body work and reparing recks since i was about 8 years old. so i know a thnig or to when it comes to building a car.
Old 03-09-2006, 03:50 PM   #14
dirtyd14
oh and knowing the people on this forum when i say since i was 8 i meen not alone that is with my father and uncle. we actully just finished up a 2000 M5 about a week ago.
Old 03-09-2006, 03:53 PM   #15
markw
markw's Avatar
And let the back peddling begin!!! I’m going to go ahead and say you’re a dreamer. If you were looking at E46 M3… and you love E30’s, why not just spend the cash on a E30 M3. There’s a few around for 15-20k, and…WOW! They already have all that E30 M3 shit you want to add to your car!
I know, I’m an asshole.
But your idea just seems………. Dumb.
-Mark
