03-05-2006, 08:46 PM
Car: 318i
inputting radio code
I changed my battery out, and i need to input the radio code into my obc, but i have a 7-button obc and i dont know which buttons to press to input my code, Any help
03-05-2006, 09:29 PM
Car: e36 m42
The radio code does not go into your OBC, you press the numbered buttons on the radio deck itself.
You have 3 chances to input your radio code before it will be locked out. Once it is locked out, you either have to disconnect the battery for another three chances, or wait with the ignition on for 1 full hour. (yes, the ignition MUST be on.)
03-05-2006, 11:44 PM
Car: 318i
Ye i know one hour  thats why i wanted to make sure..in the manual it shows the code on the obc, but i just learned you input it into the radio, Thanks
03-06-2006, 01:26 PM
Car: e36 m42
There is a different CODE that can be inputted into a 11+ button OBC. This is for when you leave you vehicle you can input a security code as an ignition kill. You will not be able to start the car again without inputting the correct code when you come back to your vehicle.
03-06-2006, 04:53 PM
7th Gear Member
Car: E36 318 iC
man, i wish i could retrofit an 11 or 18 button OBC into my car, instead of the shitty 7-button.
03-06-2006, 04:59 PM
Car: MK4 Jetta TDI
PLEASE show me how to do this!
03-07-2006, 12:09 AM
JUICY J CAN'T
Car: S54 titties
BennyL, once 98dinan3 and i install my 18 button obc, and temp sells me an 18 button obc, you can have mine, probably for free  (its got some issues though  )
03-07-2006, 12:59 PM
7th Gear Member
Car: E36 318 iC
what kind of issues?
the only thing is, that i remember justin saying that its VERY hard to retrofit an 18-button OBC into a car that has only the 7-button OBC. is this correct?
03-07-2006, 11:19 PM
Car: 318i
ye its hard to retrofit the 18 button obc into the 7 button obc, because there is alot of wire tapping to do as i learned from Justin before i bought the 18 button obc
03-07-2006, 11:51 PM
#10
Car: e36 m42
Yes, it's very difficult. Mainly to get this one silly "Check" button to work, which checks a number of your circuits.. (i.e. brake lights, tail lights, turn signals, head lights, washer fluid level, etc.) and tells you if there are any problems. A lot of wires to run to every corner of your car.
03-08-2006, 12:34 AM
#11
JUICY J CAN'T
Car: S54 titties
but mine's a 11 button, not 18 button. from what i remember, 7->11 button is direct swap (with juck norris' blessing)
its got some pixels that dont work well. other than that, it works 100%
03-08-2006, 01:38 AM
#12
Car: e36 m42
it will work, but not 100%. the check button will not work. there will be no additional functions from the 8 button, other than having a nicer (though more problematic) display.
http://www.maxbimmer.com/forums/show...3&postcount=31
03-08-2006, 11:44 AM
#13
7th Gear Member
Car: E36 318 iC
damn it, thats so depressing
so, is there a write-up on swapping from a 7-button to an 18-button? im just curious to see exactly HOW much work it is...
if not, then its ok. i just wanted to feed my curiosity.
03-08-2006, 11:46 PM
#14
Car: 318i
brother i can tell you from now ive searched alot and i havent found a 7 button > 18 button diy  lol but if youd like i can send you a DIY for a 11 button to 18 button if thats of any use for us friggen guys with 7 buttons  , Or we can make a club were our mission is to steal a few new m5's, WHOS IN??
