Old 03-02-2006, 04:41 AM   #1
Alizay
Bad Man Wagon
What should get done in a regular tune up?
Since our E36's don't have spark plug wires, I'm not sure what has to get done in a regular tune up (other than having the spark plugs changed). What other things should get done in a regular tune up for our cars, and what would any of you recommend??
---My Ride---
2003 BMW 330i M-Package (E46)
LOOKING FOR:
Smoked Tail Lights, Corners and Side Markers for my 2003 BMW 330i
BMW = Bad Man Wagon!!!
Alizay is offline   Reply With Quote
Old 03-02-2006, 04:51 AM   #2
mpower1226
mpower1226's Avatar
yes, but there are ignition wires.
anyway, for the tune ups,
-fuel filter
-cabin filter
-throttle body cleaned
-icv cleaned
-sparkplug
-coolent flush and refill.
Old 03-02-2006, 08:29 AM   #3
Miguel
...Delt Smash
Miguel's Avatar
aluminum thermostat... ALWAYS make sure to replace that.
check belts
Old 03-02-2006, 05:22 PM   #4
BennyL
7th Gear Member
BennyL's Avatar
i posted this once before. here we go again...
inspection II covers:
inspect drive belt
lube throttle linkage
replace air filter
change oil and oil filter
replace spark plugs
check brake fluid level
check battery
check coolant level and inspect for leaks
change transmission fluid
check clutch plate for wear
check drive axle boots for leak
change differential fluid
replace fuel filter
check fuel tank and lines for leaks
inspect exhaust system
check steering gear and linkages. check power steering system for leaks. check level of fluid.
inspect brakes
check parking brake
inspect front & rear suspension
inspect wheels and tires
lube door hinges, hood latch, hood hinges
check all lights
replace cabin micro-filter
check seatbelts
check washer fluid system, and fluid level
tighten nuts & bolts for door locks & striker plates
check SRS airbag ground connection
reset service light
Old 03-12-2006, 11:26 PM   #5
uber e36
uber e36's Avatar
Anyone know what inspection I consists of?
Daily: '06 S4
Wife: '05 X5 4.4i
Fun: '95 325is
uber e36 is online now   Reply With Quote
Old 03-13-2006, 01:37 AM   #6
BennyL
7th Gear Member
BennyL's Avatar
i thought you worked for BMW?
here's inspection I:
check battery
check transmission for leaks
check transmission fluid & add if needed
check differential fluid & add if needed
inspect brakes
check parking brake
check all lights
check seatbelts
check tightness of mounting screws on airbag front crash sensor
reset service light
Old 03-13-2006, 03:17 PM   #7
uber e36
uber e36's Avatar
I do, but I'm not a tech...
Daily: '06 S4
Wife: '05 X5 4.4i
Fun: '95 325is
