Old 02-28-2006, 08:52 PM   #1
slavio
Talking Clutch Removal, Need Help!!!!!!!!!
I have a 1993 325 4 door with a 5 spd and i am in the midst of removing the tranny to change the clutch. I got the exhaust off the driveshaft out the linkage is dissassmbeled the tranny under mount is out. I cant get to the top hex bolts where the top of the tranny is bolted to the engine. I NEED HELP please if anyone has done this please reply. I got a repair manual and all it says to do is tilt the engine and i did and there is still not enough room to get in there. So u gear heads gotta help me out. sigat99@hhotmail.com if u wanna email.
Please respond
slavio is offline   Reply With Quote
Old 02-28-2006, 09:36 PM   #2
BmW1718
Send a message via MSN to BmW1718
what's do you need??? i added you need a whole bunch extension and uni joints
BmW1718 is offline   Reply With Quote
Old 02-28-2006, 10:03 PM   #3
Justin e36
Justin e36's Avatar
you're going to need some super long extensions to get to those top bolts, if they're seized on there then using a pipe as an extension on your rachet will loosen it quickly. be careful when lowering the tranny that you don't get injured.
Old 03-04-2006, 12:49 PM   #4
slavio
thanx for everybodys advice
The tranny was removed it was a pain and it was a challenge but its out now.
Thanx for ur advice and suggestions
Old 03-11-2006, 07:59 PM   #5
slavio
Wink Done!!!!!!!!
I just tested the car and the clutch works good and everything is good. Anybody planning on changing the clutch with the car two feet of the ground better think again cause it was tough. Im happy now. Thanx to the guys that gave some useful hints
