Old 02-19-2006, 01:29 AM   #1
Gamite
Gamite's Avatar
another weird problem (MSN Messsenger)
Okay, I can't log onto msn. It says it cannot connect to the server.
I have all the correct ports open, and the computer that its on is a DMZ host. MSN logs on to all the other computer's on the network except this one.
Its not the account either since my friend cannot log on this computer either, but can with the other computers.
I've tried logging on with different kinds of MSN (Windows messenger, MSN Messenger 7.5, and Windows Live messenger) all have the same problem.
www.gamite.net
Old 02-19-2006, 01:43 AM   #2
Betray
Send a message via ICQ to Betray Send a message via AIM to Betray Send a message via MSN to Betray
windows firewall maybe blocking it? any weird software maybe blocking those ports? try webmessenger on it too
Betray is offline   Reply With Quote
Old 02-19-2006, 01:48 AM   #3
rodo
i duno if its related to your problem, but i can only log on msn right now but it signs off after a few seconds displaying some sort of error
2010 328i
2010 Expedition
Objects in mirror are farther than they appear Only in a BMW
rodo is offline   Reply With Quote
Old 02-19-2006, 01:54 AM   #4
Gamite
Gamite's Avatar
its not windows firewall, it still does it with it off.
www.gamite.net
Old 02-19-2006, 02:46 AM   #5
Jim .E.
E90 n00b
Jim .E.'s Avatar
dunno if you fixed it but my msn is working on both my desktop and iBook
Old 02-19-2006, 02:55 AM   #6
Gamite
Gamite's Avatar
its definately not an MSN network problem I have MSN working on two other computers, but not this one particular computer.
www.gamite.net
Old 02-19-2006, 03:13 AM   #7
Jim .E.
E90 n00b
Jim .E.'s Avatar
try making it so the one your on, is not a dmz host...
BTW what router Julian? wish thinair was on, he knows networking a lil too much
Old 02-19-2006, 03:40 AM   #8
Bill Gates
Bill Gates's Avatar
Send a message via MSN to Bill Gates
Hey Julian,
Having a host on the DMZ basically exposes that system on the web, all ports are opened. You could try Port Forwarding which is more secure since you filter ports and still have it exposed on the web.
Bill Gates is offline   Reply With Quote
Old 02-19-2006, 03:45 AM   #9
Bill Gates
Bill Gates's Avatar
check your msn connection settings and make sure you don't have any proxy settings applied. everything should be blank.
Old 02-19-2006, 04:03 AM   #10
Gamite
Gamite's Avatar
everything is blank. no proxies.
btw, your mom cut my hair last week
www.gamite.net
Old 02-19-2006, 04:14 AM   #11
Bill Gates
Bill Gates's Avatar
she told me you stopped by... i told her to give you a special cut for next time.
btw, did you use a static IP for the host on the DMZ? DHCP can still be enabled for your internal LAN, just pick one IP from that range and exclude it from the DHCP range.
you could also play with the UPNP option (similar to auto port forwarding) if you have it. there are some security concerns, only use it for troubleshooting.
Old 02-19-2006, 04:20 AM   #12
Bill Gates
Bill Gates's Avatar
does your router/firewall have logging enabled? normally this would tell you which packet(s) were dropped and by what service (port).
Old 02-19-2006, 04:35 AM   #13
Gamite
Gamite's Avatar
I checked the log, there were some packets being blocked by that particular computer, I unblocked that port, but still the same result.
www.gamite.net
Old 02-19-2006, 04:58 AM   #14
didn't read everything, but make sure your system time is correct (month/year/day etc)
if its off, the certificate wont pass, and it wont log you in
Old 02-19-2006, 06:03 AM   #15
Gamite
Gamite's Avatar
I can't believe that was the problem, that is the single most retarded thing ever.
www.gamite.net
