Old 02-13-2006, 11:57 AM   #1
atm2000
e36 fluid changes
I believe I need to change my car's fluids, I donít remember when this was last done (other then oil change) on this car. At the sametime, we can capture a to-do list for our e36s. My list so far consist of:
1. coolant flush and refill
2. oil change and refill
3. filter replacement: air, fuel, oil
4. transmission fluid flush and refill
5. brake fluid flush and refill
Is there any other items that I've might've missed? Just curious if the inspection I and II at BMW covers this or will this cost extra? Thanks.
atm2000 is offline   Reply With Quote
Old 02-13-2006, 12:14 PM   #2
BennyL
7th Gear Member
BennyL's Avatar
you missed rear differential fluid (a.k.a. final drive fluid)
inspection II covers:
inspect drive belt
lube throttle linkage
replace air filter
change oil and oil filter
replace spark plugs
check brake fluid level
check battery
check coolant level and inspect for leaks
change transmission fluid
check clutch plate for wear
check drive axle boots for leak
change differential fluid
replace fuel filter
check fuel tank and lines for leaks
inspect exhaust system
check steering gear and linkages. check power steering system for leaks. check level of fluid.
inspect brakes
check parking brake
inspect front & rear suspension
inspect wheels and tires
lube door hinges, hood latch, hood hinges
check all lights
replace cabin micro-filter
check seatbelts
check washer fluid system, and fluid level
tighten nuts & bolts for door locks & striker plates
check SRS airbag ground connection
reset service light
Old 02-13-2006, 12:17 PM   #3
BennyL
7th Gear Member
BennyL's Avatar
sorry for the double post.
to sum it all up - inspection II is paying $1000 for:
oil change
fuel filter, air filter, cabin micro-filter
spark plugs
transmission fluid change
differential fluid change
and a whole lot of "checking"
and i called the stealer to ask if they even do the transmission fluid on the inspection II, and the service guy didn't even know the answer.
Old 02-13-2006, 12:40 PM   #4
atm2000
oil change
spark plugs
the last time i checked, it was about 600 for inspection II. this was the quote i got from bmw toronto.
Old 02-13-2006, 12:53 PM   #5
BennyL
7th Gear Member
BennyL's Avatar
well when was that?
i called BMW Maranello and BMW Autohaus last week. both quoted me $995 for inspection II.
oh, and i had my oil change done at Maranello back in November. cost me $52.50 plus tax. i called last week, and now they want $75.00 plus tax. looks like im gonna do the oil change myself, or have my mechanic do it while hes got my car up on the lift to do the front pads.
dealerships raise their service prices periodically
Old 02-13-2006, 01:04 PM   #6
BennyL
7th Gear Member
BennyL's Avatar
oh, and i called the dealership for some prices.
oil filter: $17.00
air filter: $28.00
cabin micro-filter: $60.00
fuel filter: $43.00
they quoted me $22.00 each on spark plugs. this is bullshit. Canadian Tire sells the NGK Iridium plugs for $20.00 per pair, which is 10 bucks a pop. and these are the top of the line NGK spark plugs.
Old 02-13-2006, 01:11 PM   #7
M3ti Compact
Fuel Efficient 318 Member
M3ti Compact's Avatar
Any ideas on where to get which coolant, ATF and diff oil you should use?
Old 02-13-2006, 01:29 PM   #8
BennyL
7th Gear Member
BennyL's Avatar
well the guy at the dealership parts desk said BMW coolant is about $24.00 for a 4 litre jug. he also said any aluminum-compatible coolant would work, like the prestone stuff at Canadian Tire. BUT - the price difference isn't that much, and since your car has and always has had the BMW coolant, i would personally stick with it. just make sure not to use GM dex-cool!!!
and remember to mix it with distilled water. the mix is 50/50 - half water, half coolant. its easiest to mix it in a separate container before pouring it into the fluid reservoir under the hood.
for ATF, the Bentley manual designates Dexron III ATF (which is also what our cars use for power steering)
for Differential fluid:
open diff: BMW SAF-XO
limited slip: BMW SAF-XLS
Old 02-13-2006, 08:56 PM   #9
Lug_n_trug
I got an inspection II when I just got the car a while back for 500 here in ottawa? (513 with tax - I have the receipt right here).
ONLY USE THE BMW coolant - or you get pwned by sludge
Personally, I vote:
redline for tranny fluid, it works wonders.
Royal purple for oil.
ATF super blue for brakes
haven't changed my diff fluid yet, so no comments there.
Just make sure you do it all right.... lol
Lug_n_trug is offline   Reply With Quote
Old 02-14-2006, 01:35 PM   #10
vadim321go
vadim321go's Avatar
oil change
spark plugs
i did all that last week, except the tranny and diff fluid, cost me 300$ but i had a coolant flush
Proud owner of a 95 325i
Old 02-14-2006, 02:42 PM   #11
BennyL
7th Gear Member
BennyL's Avatar
did it where?
