Old 02-11-2006, 11:06 AM   #1
hioctane
hioctane's Avatar
reverse mirror swap
Hey guys. I think I saw someone do this before. Can you swap the E46 M3 reverse mirror into an E36?
Jeremy
'97 328is
"I never try anything; I just do it. Wanna try me?"
hioctane is offline   Reply With Quote
Old 02-11-2006, 04:13 PM   #2
BennyL
7th Gear Member
BennyL's Avatar
what is that? is it one of those mirrors that tilts down when your in reverse?
and shouldn't this post be in the E36 forum?
Old 02-11-2006, 06:08 PM   #3
Justin e36
Justin e36's Avatar
which reverse mirror... the windshield one, or the side mirrors?
side mirrors require modification.. (look at my avatar)
windshield reverse mirror is swappable, if you want the auto-tint and all that you'll have to do a bit of custom wiring to get 12V electricity there.
Old 02-11-2006, 06:29 PM   #4
hioctane
hioctane's Avatar
I want to swap the windsheild reverse mirror. Thanks for the info Justin.
Sorry if I posted in the wrong forum but I guess that's subjective - it's the general discussion forum.
Jeremy
'97 328is
Old 02-11-2006, 06:41 PM   #5
Justin e36
Justin e36's Avatar
no prob, I'll move it over to the e36 forum.
Since it's the windsheild mirror allow me to give a little more detail. On the stock e46 the voltage/power is run on two little electric lines embeded on the windshield itself which runs to the metal base on the mirror to power it. You will need to drill a small hole on the neck of the mirror and soldier a + and - wire to the tiny circuit board.. (VERY easy, believe me), and run that up to the roof. I have one on my car and it's a very clean install.. no one even notices there's a tiny wire going up. In your case, I would suggest wiring into the grey/red and brown wires for illuminating the sunroof switch, since it recieves constant power. If you don't have a sunroof switch, then you'll have to run it around the windsheild to your dashboard and tap it into another circuit of your choice.
Old 02-11-2006, 06:50 PM   #6
hioctane
hioctane's Avatar
Awesome; thanks! I'm looking forward to this swap.
Jeremy
'97 328is
Old 02-13-2006, 12:36 AM   #7
BennyL
7th Gear Member
BennyL's Avatar
so what exactly is the reverse mirror on the windshield? whats different about it?
Old 02-13-2006, 02:20 AM   #8
Justin e36
Justin e36's Avatar
Benny, check this thread: http://www.maxbimmer.com/forums/showthread.php?t=61966
Some have auto-dimming when headlights hit it, others have a digital compass built in as well. The red button at the bottom.. (known as the clown nose), is the light for the alarm.
J
