Old 02-09-2006, 11:51 PM   #1
vadim321go
vadim321go's Avatar
Engine problem ( yes already)
there is oil in my some of my sparkplugs, how serious is this problem and how much does it cost to fix?
Proud owner of a 95 325i
Old 02-10-2006, 04:20 AM   #2
blown head gasket, rings, could be a lot of things, were the plugs torqued correctly?
Old 02-10-2006, 07:58 AM   #3
ZiMMie
Originally Posted by proprone
blown head gasket
AHmmm NO Worn Valve guides/seals Rings or bad piston rings.
#E36-S54 #CSLWannabe
Old 02-10-2006, 08:21 AM   #4
jeffrie
Addict
jeffrie's Avatar
which side of the spark plug?
the side with the electrode inside the combustion chamber, or the porcalin side were the coil slides over it?
If the outer side fairly easy fix, valve cover gasket.
Old 02-10-2006, 08:48 AM   #5
Blades
Your opinion is to long
Blades's Avatar
if you car starts up with a lot of smoke from the exhaust .. its the rings and its time for an engine rebuild.
Old 02-10-2006, 09:36 AM   #6
R_JAY
Has the world for ransom
Come on now, don't scare the guy too much. It's probably just the valve cover gasket that needs replacing. It's a cheap part and only takes a couple hours in this weather to change. It's a very common problem on the E36's.
Old 02-10-2006, 01:16 PM   #7
325iSBimmer
///MMMM VIDA
325iSBimmer's Avatar
99.999999% probably exactly what he said^^^
I love how everyone gets on the "ur motor is shot bandwagon" and scare the shit out of the guy.
I had the same issue, when i pulled my plugs a few of them had some oil on them and it was just the valve cover gasket leaking. Its $40 from the dealership and that inludes the rings that go around the holes where the spark plugs sit and thats whats leaking the oil into the plug hole. when u pull the plugs the oil leaks into the combustion chamber and when u start the car up it might spit out some blue smoke at first but no big deal. If anything its some extra lubrication. Just make sure no dirt or grime falls in there while ur doing it.
UNDER CONSTRUCTION
Old 02-10-2006, 07:21 PM   #8
vadim321go
vadim321go's Avatar
ya the mechanic who was doing it said something but i didnt catch what it was, it is in fact the valve cover
Old 02-12-2006, 03:46 PM   #9
JUS_CRZN
My other car's a jet.
JUS_CRZN's Avatar
All that worry for nothing.
JUS_CRZN
JUS_CRZN is offline   Reply With Quote
Old 02-12-2006, 04:32 PM   #10
325isedan
325isedan's Avatar
yup valve cover diy if ur a shade tree mechanice takes less than a hour.
250KMH
325isedan is offline   Reply With Quote
Old 02-12-2006, 04:39 PM   #11
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
No, you are wrong. When you have smoke on startup it is because of worn valve guide seals. Leaking piston rings burn oil consistanty, and how would oil travel UP from below the pistons into the combustion chamber after shutting down? It leaks in from the head.
Old 02-12-2006, 06:52 PM   #12
blown head gasket,rings, could be a lot of things, were the plugs torqued correctly?
let me help you zim
its great that it wasn't anything majour
