Old 02-13-2006, 12:14 AM   #61
paul christians
87325is///MR.EVIL
I will help you to install it......pay me with FOOD......
87is325///2.7L..EVIL.....
Old 02-13-2006, 12:16 AM   #62
paul christians
87325is///MR.EVIL
Ok.....
Originally Posted by ZiMMie
quick question guru's let say ur LPF is set to 80hz do u set the amps frequency for the subs @ 80hz?
the LPF. bypass the frequency on the amp....
Old 02-13-2006, 01:02 AM   #63
BlitzSix
6 Speed
Send a message via AIM to BlitzSix Send a message via MSN to BlitzSix
Uh okay I have another question.
As mentioned several times in this thread, i have 2 10s (infiniti) 250 watts RMS each.
And today I got a free amp from a friend. It's not that great though, it's a "Mobile Authority" amp, it says 600 watts on it. It's a 2 chanell. Model is 215ZXi.
Since it says 600 watts on it that means 600 watts max right? I couldn't find what RMS it has (tried google), but I'm guessing around 300 right? So that would be putting down 150 RMS to each sub.
Obviously this isn't using my subs to their full potential, but is it ok if I hook this up? Or will I be killing the subs slowly by running them like this?
Thanks.
BlitzSix is offline   Reply With Quote
Old 02-13-2006, 06:48 AM   #64
ZiMMie
Send a message via ICQ to ZiMMie Send a message via MSN to ZiMMie
so i shouldnt set the amp @ that LPF? and when tuning my subs, i got 2 JL12W0. Only 1 subs clips while the other kept on going. wtf is that? cablin issue?
www.StanceFactory.com
Old 02-13-2006, 01:38 PM   #65
paul christians
87325is///MR.EVIL
the one sub that is cliping is on the out, take that sub out the box and push down on it and leasn to it, if sound scachy it is the voice coil. ehat amp are you using so answer you batter.
Old 02-13-2006, 01:40 PM   #66
paul christians
87325is///MR.EVIL
oh........
Thanks.
this not a good amp for your use....
Old 02-13-2006, 01:58 PM   #67
BlitzSix
6 Speed
Can you tell me why? Bad as in damaging to the subs or bad as in it won't sound as great compared to another amp?
Thanks.
Old 02-13-2006, 02:13 PM   #68
ZiMMie
Im runnin a KEnwood KAC 7201 AMP http://www.cardomain.com/item/KENKAC7201
Old 02-13-2006, 02:17 PM   #69
paul christians
87325is///MR.EVIL
that is not ture rated power, how you tell for your self is look at the fuse is uses on amp,and if is 10 or 15 amp fuse it is more like 1/2 the power that is reted at, you can use it for front speakers thought....
Old 02-13-2006, 02:33 PM   #70
paul christians
87325is///MR.EVIL
nice...
this amp looks good and yes you can tune it like you have ask.
Old 02-13-2006, 02:54 PM   #71
BlitzSix
6 Speed
Were you responding to me? The fuse in the amp is 25 amps. What does this mean ?
Old 02-13-2006, 04:06 PM   #72
ZiMMie
am gonna try runnin it @ mono and tune it to see if it will still do that to that single sub.
Old 02-13-2006, 10:54 PM   #73
paul christians
87325is///MR.EVIL
yep........
It may be ok then, give a try then.....
Old 02-13-2006, 11:06 PM   #74
BlitzSix
6 Speed
Thanks man! I'm hopefully gonna get it installed this saturday.
Old 02-13-2006, 11:12 PM   #75
JUICY J CAN'T
propr'one's Avatar
paul, you'll have all the food you want
i also just bout a PC2 lightning audio cap, made for my amp, its rated at .5 farads like i was told to get
anything else i need other than like a 4-6 gauge wiring kit a sub box?
hid headlights
